Jamaroon's ZR2
Old Jun 5, 2013 | 09:06 AM
  #91
El_Beautor's Avatar
Looks very sweet! Nice work man.
Old Jun 9, 2013 | 07:34 PM
  #92
Jamaroon's Avatar
Thanks!
Sliders got all welded up today, (thanks to blaz)
Attached Thumbnails Jamaroon's ZR2-1527d0b4-46f3-41d5-8e04-f4f33c6f2242-476-000000e8e1ce62d6_zps18854424.jpg   Jamaroon's ZR2-20903002-8a53-40b6-bb70-9b9e18b82445-476-000000e8d96a9124_zps0141558f.jpg   Jamaroon's ZR2-62100844-5007-4f6f-a39a-2eba1700f87c-476-000000f74298ed64_zpscb75719c.jpg   Jamaroon's ZR2-f6062df7-db50-459c-8f90-6518f7149160-476-000000f74b7dd64e_zps7131dc10.jpg   Jamaroon's ZR2-011cad41-55ab-43ad-a0e1-25f2e20d5603-476-000000e8ec1e53d0_zpsc08afd35.jpg
Jamaroon's ZR2-a6607e03-09d2-45cf-81e7-22b15a201dcf-476-000000e8f8ce9169_zps9dae2b67.jpg
Old Jun 9, 2013 | 07:49 PM
  #93
newguy's Avatar
Very nice
Old Jun 9, 2013 | 09:02 PM
  #94
schaffer1984's Avatar
schaffer1984 is on a distinguished road
Nice project
Old Jun 10, 2013 | 10:56 AM
  #95
El_Beautor's Avatar
That's a nice weld. Props to the welder there.
Old Jul 26, 2013 | 01:03 PM
  #96
Jake Prater's Avatar
Jake Prater is on a distinguished road
envy envy envy
Old Aug 3, 2013 | 08:00 PM
  #97
Jamaroon's Avatar
Had to swap out the blower motor/fan, what a royal pain that was..... I got most of it done last night, Paul came over today and helped me finish it up. While we were putting it back together we made a new mount for the license plate so it's no longer hanging from the grill.
Attached Thumbnails Jamaroon's ZR2-2008e1ac-8500-4d8b-97cc-43149aaa1a4d-14410-0000198f5e08009a_zpse382858c.jpg   Jamaroon's ZR2-5a0bcdbb-a37a-48fe-a20c-f0821947e8a2-14410-0000198f6836d507_zps39a5ef71.jpg   Jamaroon's ZR2-1c863ef7-727c-45c6-8e93-8455484e4af6-14410-0000198f7288386a_zps68827cd2.jpg
Old Aug 4, 2013 | 02:35 PM
  #98
TheRandom1's Avatar
I don't know what GM was thinking when they put the blower there... it's nearly impossible to get everything in and all of those bolts tight without breaking something. I always ended up missing at least one screw whenever I had to do them on my old Blazers, lol
Old Aug 11, 2013 | 02:14 PM
  #99
Sparky8542's Avatar
Sparky8542 is on a distinguished road
Originally Posted by Jamaroon
Blaz came over Saturday and Monday evening and I worked on it last night and tonight on my own to finish up installing the inverter.
[FONT=Calibri]Started by finding a place to mount the fuse. Decided to mount it to the bottom of the battery tray. Tried mounting it at a bit of an angle first, but it hit the inner fender so we had to change it.
Attached the 1/0 wire to the fuse.
Re-installed the battery tray
Ran the wire along the frame
Drilled holes for the wire to go through and installed the rubber grommet
Installed the relay under the floor, I wanted to install it inside but there was no room to put it anywhere that was easy to get too without completely disassembling the interior panels.
Crimped and shrink wrapped the wire
This shows the power and ground 1/0 cables coming through the floor and the small white wire is the relay power wire. It runs to the dash fuse block and is only powered when the ignition is in the run position.
Ran the ground to the frame and attached it using the exhaust hanger bolt. Also put the relay ground into the same terminal, that’s what the smaller black wire is for.
Then we tested to make sure everything was working with the inverter, powered the drill just fine. Went to try the little air compressor that was the whole reason for the inverter install and the damn thing won’t turn on anymore.
Then I installed some mounting bolts using some threaded inserts
Cut some holes in the carpet for the bolts and wires, connected everything and re-installed all the interior panels. Also vacuumed the carpet and wiped down the panels. This is the cleanest it’s been in a long time lol.
I figured out why the compressor wasn’t working.
I had enough wire left over to do the Big 3 upgrade, so I did that and hooked up the inverter power wire onto a brand new battery.
Grounds running to the frame:
All hooked up:
Compressor running off of inverter
And this is all that is left over from a 25’ Roll of wire
Don't want to show my ignorance but here goes anyways... What is the big 3 upgrade?
Old Aug 11, 2013 | 07:01 PM
  #100
Jamaroon's Avatar
Power wire upgrade, I did alternator to + battery, - battery to frame and block to frame
