KM346's SFA blazer (lots of pics)
Old Aug 4, 2014 | 05:35 PM
  #161
KM346's Avatar
KM346 will become famous soon enough
GL man, no turning back once you start cutting frame...
Not sure what your plan is but FWIW If i chopped my cross member off i probably could have moved the front hanger back some and got a little better shackle angle with the waggy leafs.
Old Aug 5, 2014 | 09:32 PM
  #162
blaz's Avatar
blaz is on a distinguished road
Because I didn't buy a kit I have the ability to mount the rear hangers where I need to. So I will stick with the front cross member where it is for now. Jamaroon and I had done some mock up before I asked you for the measurements. It turns out our mock up frame location was bang on. (it is good to get lucky)
Your measurement of 46" with the weight of the vehicle will fit nicely with our 44 3/4" center to center location.
Here is a sketch of the rear shackle hanger.
Old Aug 7, 2014 | 12:30 PM
  #163
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
I didn't read any of the old post but I keep my front cross member going sas
Old Sep 18, 2014 | 07:34 AM
  #164
HARDTRAILZ's Avatar
HARDTRAILZ is on a distinguished road
Nice and clean. Seems to work well. I really like it. Nice Job!
Old Oct 14, 2014 | 09:12 PM
  #165
KM346's Avatar
Well not much of an update, but I picked up a 97 Rodeo d44 over the weekend off CL to match the waggy front that will eventually find its way under this thing. 4.30 gears and open carrier... Kinda sucks but i looked all over the place and couldn't find a 96-97 rodeo (read: correct width) with a trac-lok. I may just use the gears/carrier out of this in the waggy axle, and swap a trac-lok or some type of locker into the rear if i can find one.
I was told it only had 88K, but the fluid was blacker than black and Im thinking I should pull it apart and rebuild before it goes under the truck. Luckily i low balled the heck out of the seller and got it for almost half his asking price.
Attached Thumbnails KM346's SFA blazer (lots of pics)-part_1413249873468_20141013_211147_zps146c0796.jpg
Old Nov 30, 2014 | 04:04 PM
  #166
KM346's Avatar
Another small update, I recently picked up another D44 axle with 4.30 gears and a trac-lok limited slip. (Rex found it on CL and shipped it to me, Thanks man!)
This axle is in much better shape than the other one i picked up so my plan for now is to swap the gears from the non trac-lok axle into the Waggy front and run this one in the rear.
Also,
My heat has sucked recently in the cold weather, so today i drained coolant and back flushed the heater core. Man, did that make a huge difference! The heat will burn you out of the seat now lol. I need to flush the whole system in the spring tho cause it looked like there was still a bunch of sediment floating around even after flushing the core and the rad. and adding 2 gallons of fresh coolant.
Attached Thumbnails KM346's SFA blazer (lots of pics)-part_1416969236878_20141124_173029_zpsbca4d31a.jpg
Old Dec 9, 2014 | 08:00 PM
  #167
Gregg64's Avatar
Gregg64 is on a distinguished road
My ZR2 02 is white also. I think they look good in white. yours turned out really well and looks awesome. Nice job. some day i may go the full monty and do the SAS and a V8 conversion. I have a thing for 383 stroker motors. LOL.
Old Nov 5, 2015 | 07:08 PM
  #168
KM346's Avatar
Damn I cant believe its been almost a year since i updated this. Haven't really touched the D44's since the last update... Still deciding if they are going in this truck or waiting for a different build. I did blow up the pinion bearings in the 8.8 and rebuilt it with new bearings and added a Detroit true-trac. I also fabbed some front bump stops and trimmed my fenders so my tires stopped rubbing with the sway bar disco'd. I have more than 30K on the SFA swap now!
Pics:
I have a wheeling trip planned for this weekend so hopefully ill have some better pictures/video
Attached Thumbnails KM346's SFA blazer (lots of pics)-part_1438981885906_20150807_145734_zpsbonuuwgo.jpg   KM346's SFA blazer (lots of pics)-20151101_155617_zpsfyqes3ln.jpg   KM346's SFA blazer (lots of pics)-photobucket-53104-1375391086909_zps88491455.jpg   KM346's SFA blazer (lots of pics)-photobucket-22245-1373500418763_zps0a0ec61a.jpg
Old Nov 5, 2015 | 08:09 PM
  #169
rexmburns's Avatar
Super Moderator
I've been trying to convince my son we should do this to his blazer and I think I may be getting through to him finally!
By "this" I mean a low SFA like yours lol.
Old Nov 10, 2015 | 05:44 PM
  #170
KM346's Avatar
Here are a couple flexing pics from this weekend... still waiting on a bunch of action shots/video..
Also picked up a UltraGauge MX
Attached Thumbnails KM346's SFA blazer (lots of pics)-20151107_141617_zpsuyfkem7g.jpg   KM346's SFA blazer (lots of pics)-20151107_142135_zpstq3nw3kk.jpg   KM346's SFA blazer (lots of pics)-1107151418a_zps1xeyd9ea.jpg   KM346's SFA blazer (lots of pics)-5e2707ce-7900-4e7a-9697-1f78240b385e_zpsmtid5db5.jpg
