My small 96 Blazer build
Old Jun 3, 2013 | 03:38 PM
  #511
richphotos's Avatar
Niiice, now you made me want to paint my wiper arms! lookin good brotha
Old Jun 3, 2013 | 04:09 PM
  #512
rexmburns's Avatar
Super Moderator
Thanks rich! ive been wanting to do mine forever and finally did it just cause i didn't want to work on anything big.
Not much today since it was raining and u didn't have much time at all but I made a very rough cardboard template for the half door project.
Attached Thumbnails My small 96 Blazer build-11af85e8-6210-43fa-9c8e-87a048254011-7497-000006729c94b740_zps21286a6e.jpg
Old Jun 3, 2013 | 04:27 PM
  #513
richphotos's Avatar
that is going to be pretty awesome. have you thought of a quick hinge system yet since you drive the blazer often, or your wife does I should say?
Old Jun 3, 2013 | 04:31 PM
  #514
rexmburns's Avatar
Super Moderator
I've got a bit of an idea that I think should work ok. I think I'm gonna start on the other door tomorrow since I'm pretty much at a point on this one that I need some steel and gas for the welder so I can weld without blowing through the thin sheet metal so easily.
Old Jun 3, 2013 | 07:27 PM
  #515
okiedoak20's Avatar
Rex I will stop by tuesday and maybe get in some wheel time
Old Jun 3, 2013 | 07:48 PM
  #516
rexmburns's Avatar
Super Moderator
Sounds good lets do it!
Old Jun 4, 2013 | 12:24 PM
  #517
rexmburns's Avatar
Super Moderator
Well not a lot done today just made a bracket to hold my shift controller in place since the Velcro that comes with it does nothing in the way of holding it where I want it!
On with the pics.
I straightened out the edges a bit before I painted it but its not perfect nor do I care lol
I also had to jump start it when I tried to move it today so I think my battery may be on its way out It hasn't been moved or started in two weeks. I hooked up my multi-meter and have 14 volts at idle so the alt is working.
I also figured I would see where its at with the ac on high since that causes the efans to come on high and I was wondering where I would be at voltage wise. It bounced around pretty close to 13.2 volts so I even though this should be fine I think I need to do and ad244 soon as well. I have been wanting to do it but just haven't made the time.
Attached Thumbnails My small 96 Blazer build-5f216c80-71b7-4798-877b-20499b3fee9e-644-000000d1df037f0d_zps0a02d0bb.jpg   My small 96 Blazer build-6da418e1-a989-403f-850f-b3d6d8947122-644-000000d1d96561c7_zpsea62c974.jpg   My small 96 Blazer build-afe087ae-cf61-4c14-9595-0e838062813d-644-000000d1e4ad7efe_zps090e163b.jpg   My small 96 Blazer build-9e37db2b-21d0-43fd-baa9-b26aab77001f-644-000000d3968dd616_zps15465469.jpg   My small 96 Blazer build-bec3420a-191f-4027-bfc7-825d09eb55e1-644-000000d39e87c64b_zps41b33559.jpg
My small 96 Blazer build-283b03a9-6788-44f5-a909-cdc401b76e2e-644-000000d55a11ccb7_zps7c67d0ff.jpg   My small 96 Blazer build-5ba8e0d2-5fe8-408a-9ce0-ee8235db28ab-644-000000d55446fc0d_zpsc215a40f.jpg
Old Jun 4, 2013 | 01:35 PM
  #518
richphotos's Avatar
i wish cars were still like bank in the day with the crank handle on the front LOL
what does the shift thingymajigger do?
Old Jun 4, 2013 | 03:48 PM
  #519
richphotos's Avatar
oh also, when you did your body lift, did you have to bolt any steering linkages or anything? just making sure I got everything covered when I do the cab mounts, I figure, since I only need to jack the body up about 1 inch or 1.5" i should not have to?
Old Jun 4, 2013 | 04:10 PM
  #520
rexmburns's Avatar
Super Moderator
The shift controller is an electronic shift kit it has two stages of firmness on the shifts. I didn't have to do anything with the steering shaft it just extended itself as I jacked. I do have a bit of binding in the steering now but you should be fine since your going back to stock height.
