my ZR2 build
thanks, I am quite partial to the bumper as well, I think it came together great for not really being planned. Nice thing is that I kept all the templates I made for it, so I could reproduce it fairly easily.
And yes, it was quite noise, the part that amazes me is that it started again after it had blown, I had to move it from in front of the trailer that I was towing at the time in order to hook a different truck up to it. Some how that thing fired up again and was able to pull the truck forward 20ft.
I've never had a crank break on anything I've ever worked on, but our motor sponsor had an impressive collection of broken cranks/rods/blocks/pistons etc.
This was all before camera phones or I'm sure I'd have pictures of it. lol
Removing motor mounts to drop the motor is fairly common in most shops, it's just one of those things that's routine enough you don't think about it.
If you still have the motor out you might consider "massaging" the firewall back with some high velocity steel mass to make some room and save you time next time you have to split the bell housing from the block. If I had the time I'd pull back the carpet and cut that flange off and seam weld it.
Well I got the motor in and running, I can drive my truck again, YAY!!!!!!!!!
Only thing I have noticed so far is that my low beams would not come on last night. High beams were fine, and it seemed like the rest of the auto headlight system was working fine, dash lights and everything came on. Than this morning I went out and started it and the passenger side low beam came on but it took it a minute. Still no drivers side low beam though. Every thing is hooked up and plugged in as far as I can tell, so I am not really sure yet what is going on.
Any body have any ideas?
Figured out the headlight issue, not sure why neither one would come on last night, but for some reason the drivers side low beam bulb was not making good contact any more, it wasn't burnt out, but a new bulb seems to have fixed the issue.
I would like to do the quad beam mod tho, and I am struggling to find exactly how to do it to a zr2. Can somebody guide me along a bit. Do I just need to ground out the yellow wire or?
Thanks guys, the bumper is steal. All the supporting structure for it is 1/4" angle iron, and the top and front is 3/16" plate. All said and done I think it weighs somewhere around 70 pounds or so.
As far as the crank goes my only thoughts are that it possibly had a really small defect from manufacturing and it finally gave out, but to be honest I have no idea.
I also just did the quad beam mod, and man that was the easiest mod I have done to this thing, I like it as well.
Confuused69
Mar 17, 2010 08:14 PM
