OILCOUNTRY BUILD: 2003, 2Dr, 4X4.
Old Aug 30, 2010 | 01:26 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Default OILCOUNTRY BUILD: 2003, 2Dr, 4X4.
Well I have decided to start a build thread, Ill try and post all of the pictures I have and list all the modifications I have made myself. Hope you enjoy:
Blazer with the Camaro Wheels on it..See Thread(https://blazerforum.com/forum/showth...&highlight=Z28), Tires are 30-9.5-R15 Firestone Destination A/T's
Inside I have a XM Radio Mounted, As well the Hurst T-Handle...Note for all with Manuals the Extension Stick is not a threaded ****...Found that out the hard way.
Due to rust in the Corner of the bumper step I ground it out and then proceeded to scuff and then spray rocker guard, Worked Great!. Also after being frustrated with my Flat 4 Pin connector I Mounted a Hopkins 7-Pin Connector now my wiring is always in an easy spot and looks a lot cleaner, Perfect spot as well.
Cold Air Dam made from Aluminum checker plate, Design was taken from the forum here.
TYC Carbon Tails
Clear Corners
Other Things the Blazer has:
-Over Head Console
-Blacked out Bow Tie
-Pro Comp Add-A-Leaf Short
-Throttle Body Spacer
-MagnaFlow Cat Back Exhaust
-12" MTX Sub
-New Transfer Case
Any other pictures request feel free to ask!
Old Dec 12, 2011 | 12:54 PM
OILCOUNTRY's Avatar
Well Picked Up a hood from the local classifieds this summer, Here are some pictures...
Today I am Picking up some ZR2 T-Bars and Also will be picking up some new Rear Leaf Packs to replace my Saggy Rear End. My Drivers Side Rear has sagged out really bad and in the summer not all that noticeable but now the roads have gotten slick I really notice the pull.
Old Dec 12, 2011 | 04:16 PM
blazin=blazer's Avatar
blazin=blazer is on a distinguished road
blazer looks good man.
Old Dec 12, 2011 | 04:56 PM
TheRandom1's Avatar
Looks really nice!
Old Dec 12, 2011 | 05:11 PM
OILCOUNTRY's Avatar
Thanks Guys,
Now I am looking to work on the front end components, Mainly the Ball Joints, Control Arm Bushings, Torsion Bars, and the Rear Leafs, I have a set from a low miles ZR2 i am going to install.
Old Dec 12, 2011 | 05:25 PM
ohsofly's Avatar
The control arm bushings are a **** to remove... I used my ball joint press and a couple hours to do all 8.
Old Dec 12, 2011 | 05:45 PM
OILCOUNTRY's Avatar
Ah ok I will More than likely be working out of my Dads Truck shop to do the next bit of work I have Planned where there is any tool I will need including a Hydralic Press.
ohsofly , Did you see the cowl hood for sale on Kijiji for your 93? The guy is asking $300 and It sounds like it is new
jimspahr@msn.com
Aug 7, 2013 06:51 AM
00chevy
Mar 18, 2013 06:38 PM
george154302
Aug 30, 2012 06:37 AM
bgummer
Aug 5, 2011 03:09 PM
gails61
Mar 14, 2011 06:26 PM
