I take back what I said about my transfercase having a hairline crack. It was a little worse than I realized... It came apart in a few more pieces than it should have.
Got my fixed front output shaft swapped over to the new t-case and got the t-case back in the truck. Got a little bit more reassembly to do in the morning, and she will be rolling again- without spraying tranny fluid everywhere lol
Glad you fixed that one. Did it hit somewhere or just a crack that has extended over time?
My theory is that it cracked slightly at the end of last year when I lost both my driveshafts and broke my transmission crossmember. Then it opened up after some hard use.
Originally Posted by rriddle3
Meh. Just needs a little JB Weld!
Funny thing...when it started leaking a little bit at the mud fest, me and my buddy crawled underneath and saw a tiny crack in the case. We figured might as well throw some jb weld on it to keep the fluid in so we can keep riding. That didn't work and the leak got way worse so I parked it.
now fast forward to this weekend. Me and same buddy pull the case out and find the massive crack in it. Then start cracking up as we look down and see the little spot of jb weld the size of a quarter - on a completely different section of case.
Got it all buttoned up today and she's driving around again- now without spraying tranny fluid everywhere lol
Well, at the off road event a couple weeks ago the Transfercase held up well. I blew a wheel cylinder going down the side of the mountain, so but was able to get it turned around and back to camp without brakes.
Did both new rear wheel cylinders and brake shoes and springs in the field and got it going again.... only to have both engine mounts and tranny mount let loose on me... right around this time:
after some research I found out the factory style mounts are problematic for everyone running more power or bigger tires/lockers on s-series trucks. Solutions were chaining the factory mounts so they couldn't pull apart, or running polyurethane mounts. I chose to get these mounts from energy suspensions because they have internal hoops to protect the mounts from pulling apart, so they're even more reliable than regular poly mounts, and I shouldn't have to worry about chaining them.
Also, here's one more picture from the event.
My blazer, the once-was Minnie Jimmy, and the sonoma which my girl has claimed to be her off-road toy lol.
