Project Sleeper Blazer
#201
I have not done much lately with it other than drive it an enjoy the last few days of above freezing temps here haha.
Also i agree with your last post....i hate1/8 mile racing. but that is all that was available close to me this season otherwise i have to drive 3+ hours to get to another strip.
This track was trying to run 1/4 but was having some issues with their track at the top end.
I just put the Blazer away for the winter and put her up on stands to do some work underneath like welding in my driveshaft loop and looking everything over after the season.
I also picked up another 6.0 engine for cheap that im going to build properly to replace the current stock bottom end LQ9.
#202
I figured while i had it up higher than the ground i would take some pictures of how my newer exhaust is ran. dual 3in pipes are hard to fit, so i had to notch one of the crossmembers and they go to a Y-pipe after the mufflers. Also, the metal band clamps are not perfect at sealing, but it allows me to quickly and easily separate the exhaust and drop it completely out of the truck in 4 pieces for maintenance.
Not great pictures, but gives a good idea of the exhaust.
#205
As always, project looks good! Keep it up! Isn't that hammertone finish paint the coolest thing for painting rollbars with a brush!!! Looks so nice after it is applied!
#206
I did not add any reinforcement to it yet. I plan to box it back in when i feel like tearing it apart again, but it has not been an issue.
#207
Well i tried to have the driver seat modified to fit the race belts through the headrest and i did not like how it turned out.....So i ordered some racing seats and sliders>
I drilled the rivets out that held the factory sliders to the factory bracket this way i could reuse the factory floor brackets.
Then i used some steel to make cross braces/brackets between the factor brackets and
BTW....please don't judge my welds. They are not the prettiest, but they are strong.
I then welded the racing seat sliders to those cross braces. For the drivers seat, i actually welded the sliders on upside down so the handle will be tucked further under the seat since i don't move the drivers seat often.
And the finished product for the driver side.
Its not perfect, but it works for me and fits great.
#209
I finally got a picture of the finished product for the seats.
I also added a tilt steering column while i had it apart to make getting in and out easier.
I was able to keep the factory belts working like stock if wanted and have the 5 point on the drivers seat for racing. But i usually just use the 5 point when i drive it.
#210
And now for the next phase of the build.......Forged bottom end with ARP main studs to build a proper engine to take the boost and not worry about windowing the block.
I just have to get the time to take my spare 6.0 block to the machine shop and get the machine work done.
