Project Sleeper Blazer
Old 02-03-2023, 08:18 PM
ChuckNTruck's Avatar
Party Time!
I decided to go with 35 spline axles, an Aluminum thru bolt center with a detroit locker and 3:70 gears. Hopefully this will hold....Haha
  #252
Old 02-03-2023, 08:22 PM
After welding on the sway bar brackets it got a nice powder coat finish.
And some disk brakes
Brake lines are not the prettiest, but they will work for now and are protected from how i like to strap the Blazer onto my trailer.
  #253
Old 02-04-2023, 10:23 AM
LesMyer's Avatar
LesMyer will become famous soon enough
That one should be bulletproof!!
I took out the full spool and put an Eaton Posi back in my S10. Also went with a more streetable camshaft. Really like those M/T Street Radials you told me about. Haven't gone down a track in it since 2000
  #254
Old 05-08-2023, 11:19 AM
LesMyer's Avatar
Chuck!! Need an update!!
  #255
Old 05-11-2023, 09:15 PM
Sadly, the blazer has been put on the back burner for a bit. I had a family member pass away while i was deployed, so i inherited a couple classic cars (1968 Chevy II SS and 1955 Nomad) that i want to get put back together and roadworthy in his memory. Currently rebuilding the 350 sbc from the Chevy II and rebuilding the brake system on the nomad. Luckly both cars have Muncie 4 speeds so the trans don't need much work other than a reseal. But both cars have been sitting since the early 90s so they need a a lot of work just to get back on the road safely.
About the only update i have for the blazer is that i had to get a new driveshaft due to the 9in requiring a 2in longer driveshaft. I will have to get some picture of the fully installed 9in and driveshaft.
Other than that i have just driven the Blazer few times so far this year. Hopefully i will get it back on the track at the end of the month to see what kind of times it turns with the 9in setup.
  #256
Old 05-14-2023, 05:28 PM
LesMyer's Avatar
Great - keep us posted!
  #257
Old 05-14-2023, 10:22 PM
Nyshadow's Avatar
Nyshadow is on a distinguished road
I'm sorry to hear about the passing. My condolences.Question, I have a 2000 2 door blazer like you. Mine is 4X4 though ZR2. Would it be possible to swap in a 5.3 and keep the 4x4 intact? It's going to be a daily driver.
  #258
Old 06-05-2023, 04:23 PM
Not a huge update since i still need to get some pictures of the finished diff install.
But she moves with the new diff and E85 tuning.
rolled across the scales last weekend at 4140lbs with me in it and below was my fastest run.
It was consistent all day long in the low 10.60s and allowed me to take 2nd in my bracket class.
  #259
Old 06-05-2023, 07:47 PM
Chevymec's Avatar
Chevymec is on a distinguished road
Heck yeah!! Are you gonna try and make an appearance in to the 9's?
  #260
Old 08-03-2023, 09:48 AM
LesMyer's Avatar
Hi, did you ever make it back to the track after swapping in the new rear?
zs_v8jimmy
07-22-2017 09:33 AM
HotRodHearseGuy
03-04-2014 07:12 AM
HotRodHearseGuy
08-18-2013 09:11 AM
LIFTED-JIMMY
Engine & Internal
12-27-2012 11:25 AM
xc2strokestomper
Performance & Brainstorming
11-09-2009 08:41 PM
Quick Reply: Project Sleeper Blazer
