PROJECT solid axle swap/lift
Old Feb 12, 2010 | 10:10 PM
  #101
xtreme821's Avatar
xtreme821 is an unknown quantity at this point
haha no worries, i see how i could have confused you.. gonna check starter tomorrow, all other grounds look nice, even re ran some.
so next question, what transfer case is easiest way to make my truck 4x4 again? i know i need a passenger side drop, what are the differences in length and all also?
Old Feb 13, 2010 | 09:13 AM
  #102
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
Transmission?
Prob a NP208
Old Feb 13, 2010 | 10:28 AM
  #103
xtreme821's Avatar
how can i tell if the trans is a 700r4 or 460le ?
Old Feb 13, 2010 | 11:17 AM
  #104
old skool luvr's Avatar
Originally Posted by 86Blazer327
....... I have to do this with customers all the time because they get simple terminology confused and in turn confuse the pizz out of me.
try aving that problem with family! sometimes it's a RPITA being the family mechanic.
while i've never had any trans newer than a '93 apart (yet), i'm gonna guess dropping the pan is gonna be the most obvous part. also, i think the plug is different between the two as well (not 100% on that one though).
what year is the truck again?
Old Feb 13, 2010 | 11:19 AM
  #105
xtreme821's Avatar
1992 s10 2dr sport
Old Feb 13, 2010 | 03:17 PM
  #106
abig84's Avatar
Doesnt really matter. 700r4 and 4l60 is the same trans. size size and case. The np208 is basically the same size as the transfercase thats in there. I put it on the back of my 4l60 and used the factory rear driveshaft. Only issue as ive stated before if you have the 4l60 the VSS is in the tailshaft of the transfercase. So id you swap cases you lose the ability for the trans to shift
Old Feb 14, 2010 | 09:52 AM
  #107
xtreme821's Avatar
any way to swap and still shift ?
Old Feb 14, 2010 | 01:05 PM
  #108
abig84's Avatar
i am able to manually shift. start in first and pop the shifter up. but as for the correct way. no idea. ive heard talk that you can put in a 241 out of like a 91 k5/suburban and its supposed to have the vss hook up. also that they sell a adapter you can put in the np208 but really didnt look into it or care all i use is first gear.
Old Feb 14, 2010 | 08:52 PM
  #109
xtreme821's Avatar
anybody know about this 208 vss adapter ?
http://www.jagsthatrun.com/v8-s10-in...fferential.pdf
is this any good to do ?
http://www.jagsthatrun.com/Pages/Par...ctor-Diff.html
Last edited by swartlkk; Feb 15, 2010 at 06:51 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not replied.
Old Feb 15, 2010 | 06:51 AM
  #110
Looks like it would work until you bounced it off a rock or two...
