PROJECT solid axle swap/lift
Old Feb 15, 2010 | 10:00 AM
  #111
xtreme821's Avatar
xtreme821 is an unknown quantity at this point
yeah it needs a cage or something fabbed up.. rocks im not worried about, here in nj its clay. maybe just a bottom skid plate thing, i dunno.
for 80 bucks its worth a try in my opinion.
Old Feb 15, 2010 | 12:02 PM
  #112
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
Youll tear it up. Get a manual valve body and call it a day
Old Feb 15, 2010 | 01:19 PM
  #113
abig84's Avatar
I might have meantioned this before too but you're gonna have to mod your crossmember or get another one with the 208. The front output shaft goes right into it. Perfect time to make one that will hold a skid plate
Old Feb 15, 2010 | 03:47 PM
  #114
xtreme821's Avatar
whats a maual valve body ?
and you did mention it, a was already planning on making one with like a driveshaft hoop and skid plate to protect the transfer case
Old Feb 15, 2010 | 07:38 PM
  #115
old skool luvr's Avatar
Originally Posted by swartlkk
Looks like it would work until you bounced it off a rock or two...
oh yeah, i can just see that happening!
and clay wouldn't be an issue? getting all clogged up in the ring, between the sensor & ring, etc.
you can send me the 80 bucks if you wanna toss it away.
Old Feb 15, 2010 | 07:56 PM
  #116
xtreme821's Avatar
haha i guess you guys are right, whats this manual valve body thing ?
Old Feb 15, 2010 | 09:03 PM
  #117
well, you know how you can put your auto trans in "D" and just go, a manual valve body is just that-you have to manually shift the trans between the gears.
think of it as an early paddle shifting trans.
Old Feb 15, 2010 | 09:47 PM
  #118
abig84's Avatar
heck then just don't hook the vss up that's how my trans is now
Old Feb 15, 2010 | 10:07 PM
  #119
but the manual valve body is designed for that.
i'm sure a disconnected newer trans won't last too long, shifting like that
Old Feb 16, 2010 | 09:04 AM
  #120
Does this thing have a place for a cable speedo?
Like said already , a manual valve body wont shift on its own , you have to do it. Its like having a stick shift with out the clutch. And as stated , they are made to be shifted in that fashion.
Edit- The NP208 should have a cable provision. Just get a VSS from Jags that run for a cable operated Xfer and be done with it. They screw on where you would normally put the cable , then plug your VSS harness into it. Done. I think they are about 60-80 bones
