PROJECT solid axle swap/lift
Old Feb 16, 2010 | 01:53 PM
  #121
abig84's Avatar
Originally Posted by 86Blazer327
Just get a VSS from Jags that run for a cable operated Xfer and be done with it. They screw on where you would normally put the cable , then plug your VSS harness into it. Done. I think they are about 60-80 bones
i'm sure a disconnected newer trans won't last too long, shifting like that
yeah that makes sense especially if this is gonna be a daily driver. i dont shift mine. it only sees first gear. ocasssssionaly ill put it in 2nd if im on a long straight away.
post up pics and what you get and if it works. if its a simple deal i might just get one for the heck of it
Old Feb 17, 2010 | 04:44 PM
  #122
xtreme821's Avatar
xtreme821 is an unknown quantity at this point
you guys are all confusing me, haha
where would this vss screw on if theres no vss that comes stock ?
i checked all my grounds yesterday, still not enough juice to turn motor fast enough to start. i think i am going to finish cutting old **** off tonight and throw the fender back on tomorrow and pull it to my mechanic friends shop. make it his problem..
http://www.jagsthatrun.com/Pages/Spe..._Reluctor.html
does this do the same thing ?
Last edited by swartlkk; Feb 17, 2010 at 05:00 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT function to add additional information to your post if another member has yet to reply.
Old Feb 17, 2010 | 05:02 PM
  #123
That setup will not correct for LO range operation.
I am going to use a mechanical to electric conversion box on my K5 when I put the TBI motor in. It takes the mechanical speedo output from the transfer case and converts it to a square wave signal.
Old Feb 17, 2010 | 05:05 PM
  #124
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
Starter may be dragging
Here is the link for the speed sensor. You need #1
http://www.jagsthatrun.com/Pages/Spe...eedometer.html
Old Feb 17, 2010 | 05:17 PM
  #125
xtreme821's Avatar
its a brand new starter. gonna load test my battery, see how many amps its putting out. would not having the correct amps shut the truck off if its running though ?
okay so i need a two pulse, but where does it screw in to ? thats what im not understanding. the one kit had a reluctor ring on the output shaft and then you had to drill and tap for the sensor, i dont see why that wouldnt work ? wouldnt it only affect 4LO if its mounted on the transfer case output shaft ? that one showed it on the trans output before it even hit the transfer case
Old Feb 17, 2010 | 05:45 PM
  #126
If you put a NP208 case in your truck , like you have said you needed to do to get a passenger drop , you would take the sensor I linked and screw it into where the cable would go on the NP208. Then you solder the wires into your VSS pigtail. Presto , speedo signal!
Load test your battery? I thought you said it was good.
Figure out whether or not your battery is any count.
Like I said earlier , you may have more than 1 problem. First thing is to get is spinning. And new starters will junk out quicker than old factory ones depending on the brand.
Last edited by swartlkk; Feb 17, 2010 at 05:48 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT function to add additional information to your post if another member has yet to reply.
Old Feb 17, 2010 | 06:12 PM
  #127
xtreme821's Avatar
okay so this weekend when i get the transfer case i will look at it and see a hole in it where a speedo cable used to be? and in that very same spot i put my vss and my factory pigtail will read the gears the same as it would now?
load tested, put out 1.2 amps under load which im told is normal. the old factory started is the one that took a **** on me and now the new one still doesnt turn fast enough..
thanks for putting up with me by the way
Old Feb 17, 2010 | 07:57 PM
  #128
On the back of the 208 will be a spot for a cable. Buy the sensor from JTR and screw it in where the cable would normally screw in. Then solder your VSS wires from your harness to the new sensor. Presto Chango - VSS solved.
Unless you get a later model 208 , which could have a factory VSS already in it. Go get it and see what you have
Old Feb 17, 2010 | 08:51 PM
  #129
xtreme821's Avatar
okay will do.
thanks guys. we'll worry about the linkage to actually shift from 2 to 4 once i get it, haha. one problem at a time. was going to cut off some excess brackets tonight but its like this misty snowy mix right now..
Old Mar 5, 2010 | 01:38 PM
  #130
xtreme821's Avatar
so she rolls. still no start. monday she goes to the shop. need shocks for the front, should i use the stock mounting brackets and find 22" long shocks or you think itll be worth making new tabs lower on the frame ?
