PROJECT solid axle swap/lift
Old Apr 12, 2010 | 10:45 PM
  #151
old skool luvr's Avatar
glad to see you finally got the t-case.
Old Apr 13, 2010 | 08:15 AM
  #152
xtreme821's Avatar
xtreme821 is an unknown quantity at this point
thanks. yeah haha i finally had the time to drive up north to pick it up. gotta run to school now but im gonna order he sensor later. my trans is angry at me after i held the gas pedal to the floor through a swamp the other night. it doesnt want to shift out of first gear.. you think its blown ? it was low on fluid when i checked it- would changing the filter and fluid make it come back to life?
Old Apr 13, 2010 | 07:06 PM
  #153
abig84's Avatar
check the vacuum line going to the trans (if it has one forgot what trans you used) make sure its got vacuum if so check the actuator too
Old Apr 14, 2010 | 03:09 PM
  #154
xtreme821's Avatar
its a 4l60e
Old Apr 14, 2010 | 03:57 PM
  #155
abig84's Avatar
Mine doesn't shift due to the vss not being hooked up that might be a good spot to check. See if the wire got tore off
Old Apr 26, 2010 | 09:27 AM
  #156
xtreme821's Avatar
got my new trans yesterday. 4l60e with 47k miles on it
hopefully the rain lets up tomorrow and i can blow it all out in one day. anybody know any tips or tricks to drop the old trans ?
mud hop is coming quick, gotta make a front driveshaft!!!
Old Apr 27, 2010 | 04:14 PM
  #157
xtreme821's Avatar
yeah so i have the 4l60 not the electronic one.. apparently 92 was an in between year? i dont know.
Old Apr 27, 2010 | 10:03 PM
  #158
abig84's Avatar
wouldnt that make it a 700r4 then? i think the way to tell is the 700r4 has a actual kick down cable where the 4l60 just has the electrical. i dont really know but i could see their being some weird in between year trans that costs like $2000 from the junkyard cause they only made it for one year
Old Apr 28, 2010 | 12:40 PM
  #159
xtreme821's Avatar
yeah i got confused again, i need the 700r4
damn chevy
Old Apr 28, 2010 | 12:44 PM
  #160
4L60 means the same thing as 700R4. They changed the name at some point to better align with the rest of the automatic transmission nomenclature.
