Rough Country 2.5" Lift!!!!
Old May 13, 2012 | 01:40 AM
  #301
Private_Ops's Avatar
Private_Ops is an unknown quantity at this point
Good to hear, lookin to install this kit on my Z and use it for about 2" of lift (I dont like anything beyond a 1" BL). Probably will be enline with the 1 Ton Idler Arm conversion kit from Synergy Offroad as well.
Old May 13, 2012 | 04:46 AM
  #302
EricR's Avatar
EricR is on a distinguished road
Have they updated the kit to fix these problems? The website now says it keeps the CV angles where they should be and what not but is this really true?
Old May 13, 2012 | 07:16 AM
  #303
Rottidog's Avatar
A friend & I installed this kit on my blazer a couple weekends ago & so far I haven't had any issues with CV joints or boots.
Old May 13, 2012 | 12:50 PM
  #304
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Can you post a picture of how yours are angled? And i assure your cranked up 2.5"s?
Old May 13, 2012 | 03:03 PM
  #305
Rottidog's Avatar
Cranked up 2.5"?
It's lifted from stock the 2.5" that the kit does BUT keep in mind I had the t bars twisted an inch & 1/2 so I really I only got an inch or so perhaps of lift.
The benifit of installing the kit was better angles on the cv's & the TB's at a "stock" twist for better road manners ala the keys in the kit - not as harsh as with them twisted. Not to mention the tubular upper control arms that should be a lot stronger than the stamped steel POS that I was bending because of the 32 x 11.5 on 10" wide rims.
I'll get a pic or 2 tomorrow of the CV's etc.
Old May 13, 2012 | 05:19 PM
  #306
10" wide rims
Why? 8" is fine on anything up to a 12.50" wide tire.
Old May 13, 2012 | 06:18 PM
  #307
Rottidog's Avatar
They came with the 33" tires I got a couple years ago. When I switched tires to the 32's I had them mounted on those rims because A: I had them & B: they're not stock.
Old May 14, 2012 | 06:35 PM
  #308
PaulO2288's Avatar
Cranked up 2.5"?
I understand. Did the diff drop make that much of a difference to help level out the cv's? If so around how much do you think?
Old May 15, 2012 | 09:37 AM
  #309
Rottidog's Avatar
Yeah they look a LOT better than when I had it with 1-1/2" T bar twist. I'll see if I can get a pic or 2 of how they are now. The angle of them is much nicer to the front end componants & the t-bars being back to a stock twist ala the keys that came with the kit makes the ride a lot nicer to me.
Old May 15, 2012 | 07:40 PM
  #310
Rottidog's Avatar
Here's how the CV's sit now with the RC kit.
