Rough Country 2.5" Lift!!!!
Old Feb 2, 2012 | 11:34 PM
  #281
war00's Avatar
war00 is on a distinguished road
i just bothers me because i have a weird sound coming from my psg and im almost 90% sure that its my cv axle binding up when going over dips in the road. but since getting it aligned today its gotten a little better. when i jack the truck up and let the suspension drop, i can spind the driver side wheel but i cant spin the psg side. but if i jack the psg control arm up 1/2" i can spin the wheel fine. i dunno if im missing something or what. im a licensed lic mechanic and having a troubles figuring this one out.
Old Feb 2, 2012 | 11:37 PM
  #282
xgiovannix12's Avatar
check your tbar cross member possibly one of the mounts are shot
its a common problem on these trucks
you just need to crawl under and see if it has play
Old Feb 2, 2012 | 11:46 PM
  #283
war00's Avatar
hmmmm...........maybe i shall check them out as i did just have the whole suspension apart and i did question those bushings. but when calling around to local part stores no one carried them or had a clue wtf i was talking about lol. when you say play in cross member which way do you think the pay would be up/down side to side. cuz i have play front to back but the way the top bushings are designed it looks like that would be normal. tho i dont know much about these trucks im a diesel mechanic by trade.
Old Feb 2, 2012 | 11:52 PM
  #284
up and down
the stock bushings are rubber
they came out with a new better type of bushing for the cross member that i will soon upgrade both sides my self on my rig since one of mine is on its way out
these are the new improved versions of them
http://www.ebay.com/itm/200695246767...84.m1423.l2649
Old Feb 3, 2012 | 07:04 AM
  #285
TheRandom1's Avatar
Originally Posted by war00
thats what i thought too but i measured from the ground to the center bottom of the fender on both sides and they were the same. to get my measurement difference of 1/2" i actually crawled under my vehicle and took the measurement at the the cv going into the diff/axle tube to the ground.
You want to measure from a fixed spot on the rim instead of using the ground when measuring height. That way you take any possible tire under inflation/over inflation/etc out of the equation.
Old Feb 3, 2012 | 08:25 PM
  #286
Birdman's Avatar
Birdman is on a distinguished road
How does this kit ride as opposed to the t-bar tweak?
Old Feb 4, 2012 | 12:07 AM
  #287
war00's Avatar
i had a tbar tweak before i installed this lift and the ride was rough, rode like a bag of bricks. with the lift installed and aligned properly its alot better than before a little stiffer than stock but not as bad as a fully cranked tbar. plus it "should safe the front end from wearing out parts" but only time will tell. ive only being riding on this kit for 3 days but have had it since before xmas.
Old Feb 4, 2012 | 09:33 AM
  #288
SwampThing's Avatar
SwampThing is on a distinguished road
Can anyone post a side by side pic of a stock blazer compared to a lifted (2.5" rcx and 2" bl)? Thanks!
Old Feb 4, 2012 | 01:10 PM
  #289
El Diablo793's Avatar
El Diablo793 is on a distinguished road
Yup. Ripped ANOTHER CV. Getting it fixed by Rough Country and then selling it and getting a GMC fullsize. Im not dealing with this anymore. It seems that everyone has problems with this kit- even their test blazer has problems with it. Screw it all...just done with faulty products.
Old Feb 4, 2012 | 04:09 PM
  #290
war00's Avatar
Which cv do you keep ripping? Psg? Thats the side im having problems with
