s10 blazer build
Old Jan 11, 2013 | 07:26 PM
chevy-s10's Avatar
chevy-s10 is on a distinguished road
Default s10 blazer build
i looking for some input i want a nice lift kit on my blazer it goin be between a 95-04 model i live in virginia so i am not sure the max height you can have in state of virginia but i like to go as big as i can and just need some help on where i can find some kits for the best lift body kits and what the best axles to put under it hope i can get some good feed back been looking at some of the blazers on here and they look great
Old Jan 12, 2013 | 09:57 PM
jbb421's Avatar
jbb421 is on a distinguished road
Best lift for the money is a SAS (Solid axle swap) here is a good weld on kit https://www.4wdfactory.com/store/pro...xle-Hanger-Kit Bolt on kit: 94-04 S10 Solid axle swap Bracket kit Your still going to need axles i personally got mine from a Wagoneer they are narrow track Dana 44s so no need to shorten them, alot of people also run dana 30s. You will also need brake lines, a front driveshaft from a Cherokee, and a slip yoke eliminator or a yoke from an older blazer for the transfer case. you will get ~ 4-5 inches of lift with running axle under leaf on the rear about the same sas swaping the front and running axle under leaf (dont hold me to that). If you have any other questions lmk, and ill do the best to answer them.
Blaze1Chef
Mar 7, 2021 10:44 AM
Minichick
Dec 4, 2013 09:57 PM
ray00m
Oct 12, 2011 12:49 PM
bobditts
Aug 25, 2009 04:26 PM
