A thoroughly British Blazer Build
Yeah, will be doing it myself. What gauge cable would you guys recommend? The good thing is it had a new alternator last year and the battery is only a couple of years old so the charging system is in decent condition.
I grabbed a couple of hours out in the garage yesterday and made a start on my light bar. Its made out of some angle and some box section steel and designed to bolt up to the factory roof rails using some captive nuts I will make. (two per side.) makes it totally reversible and fairly low profile. Got everything cut out and drilled and prepped to weld up. Just need to make a tab to weld on the back of it so i can put a CB antenna up there too and then weld it together. Then a coat of paint and sort the electrics out.
I need to find someone local to me with a tubing bender so I can make something for the front bumper for my pair of big Hellas.
I'm going to make some captive nuts by welding them to a steel plate the right size to slip into the roof rail, two 8mm bolts per side should stop the bar twisting or lifting. Does mean I need to take the roof rails apart at one end to get the nuts in but it also means its totally reversible should I sell it. Bolts will be loctited in. The lights are also pretty small so its not like whacking four dinner plate sized spots up there so wind resistance will be fairly low.
The lights are Hella FF75's like the ones on this nissan which was my inspiration.
