Torbinator's Cheap Jimmy
#31
Great brake lights! Honestly they look amazing. Just never put a halogen in like I did. Melted off the tabs that held the reflectors in. I liked them so much that ill probably buy another set even though these are only a month old and nearly started a fire 😂
One thing ive been thinking of regarding rear brake lights. I saw a Blazer on youtube awhile ago that had LEDs inside the rear window trim of his 2dr inside the two holes on each side. They lit up whenever brakes were pressed. Wondering how he got those in there. Id like to do the same!
#32
Lovin' the new gauge face I got on. Not a big fan of it in the daytime but wow it looks great at night. Any opinions? $40 and a little bit of time. Fuse tapped into the illum fuse in the interior box so it dims with everything with the scroll wheel.
#33
I like electric fans because I spend most of my time driving at very slow speeds in warm weather, and the electric fans cool very well under those conditions, especially with the air conditioning on. I also have a 2-inch body lift and it's nice to not have to mess with the fan shroud.
#34
#35
Since I didn't need any of the bumper brackets or other stuff (I built my own bumpers, run electric fans, and have no problem fabricating any other parts I might need), I saved a few bucks by making my own "kit" . I bought just the blocks from Zone Offroad and obtained the bolts locally. If your Blazer is relatively stock, though, I think you'd be better off buying the kit.
#36
Well... So I noticed today my oil pressure wasnt at normal operation. Normally at idle its around the half way mark, now its at the quarter mark. WOT is usually 3/4ths, now its a little over the quarter tick. Checked the oil and it doesnt register on the dip stick. Oil change was like 3k-4k miles ago. And all of a sudden no coolant as well. Its held coolant well since the head gasket change, i checked it few weeks ago and was still perfect. All of a sudden its empty but the truck still holds right under 210. The no oil has me worried... Gonna do an oil change and see how quickly it disappears. Hopefully all is well...
#38
Apparently not enough. I of course check it every 5k miles for oil changes. Its very rare for me to check it otherwise but of course I noticed a change in oil pressure from today and yesterday and a random pop whenever I start my engine. Dunno what the pop is coming from. Thought it was the steering wheel but it must be something else.
#39
Hopefully I didn't bust anything. I have the 5 speed so I regularly let it go up to 4k rpms and then shift which my shifts are smooth and I do it after its warmed up but maybe these engines are weaker than I thought? Or its something else...
#40
Only 122k miles....
Only 122k miles....
