stripping wheels
There is paint stripper which is a chemical. Be sure that if/when you do this that you do so in a VERY well ventilated area.
I did this on a set of 1st Gen Dodge Intrepid rims and some of the paint was an epoxy coating which didn't come off anywhere near as well as the clear coat. I ended up having to sand blast them to get them clean.
don't use anything with HCl acid in it. Ever seen a 'works' bomb? The acid reacts with the aluminum foil and gives off a gas that blows up the bottle. Aluminum is destroyed by certain acids.
kurslt
Oct 14, 2009 06:21 PM
thevair65
Jan 31, 2007 02:02 PM
