Detailing Discuss detailing your Blazer within.
stripping wheels
Old Mar 26, 2007 | 02:35 PM
dusted800's Avatar
dusted800 is an unknown quantity at this point
Default stripping wheels
What works good to strip the old clear coat off my aluminum rims. I tried a wire brush in my drill but that will take forever. There must be some chemical that will remove it. thanx. wnk.
Old Mar 26, 2007 | 03:15 PM
Default RE: stripping wheels
There is paint stripper which is a chemical. Be sure that if/when you do this that you do so in a VERY well ventilated area.
I did this on a set of 1st Gen Dodge Intrepid rims and some of the paint was an epoxy coating which didn't come off anywhere near as well as the clear coat. I ended up having to sand blast them to get them clean.
Old Mar 27, 2007 | 10:41 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Isn't there an acid you can use too? I vaguely remember back in my car washing job in high school, something about an acid that will remove tar, and clearcoat from wheels.
Old Mar 27, 2007 | 11:14 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
don't use anything with HCl acid in it. Ever seen a 'works' bomb? The acid reacts with the aluminum foil and gives off a gas that blows up the bottle. Aluminum is destroyed by certain acids.
Old Mar 31, 2007 | 12:05 PM
Peco's Avatar
Peco is an unknown quantity at this point
Heres a how to: http://www.thepontiactransampage.com/clear.html
kurslt
Oct 14, 2009 06:21 PM
kmartin
May 4, 2009 05:17 PM
BlackBlaze
Mar 26, 2008 04:37 PM
alphagtp
Mar 10, 2007 10:49 PM
thevair65
Jan 31, 2007 02:02 PM
