1993 4.3L vortec - idea to ponder, not for faint of heart
Old Feb 23, 2010 | 12:04 AM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
Default 1993 4.3L vortec - idea to ponder, not for faint of heart
so here is my thought. MORE COMPRESSION RATIO
i think im running about 9.1:1 OEM, i think i want more like 10.5 or 11 : 1 ratio
take a stock 4.3L vortec of 1993, let it breathe (intake, exhaust)
then work with the heads, cam, fuel system
then add a nice posi rear.
HEADS-
im curious if the heads can be swapped with any others for smaller chamber cc.
example - the V8 307 can benefit a lot by swapping the stock heads for 305 heads (114 casting i think) as it goes from around 76cc to 56cc chambers. Does anyone know about this type options with maybe a 3800 or something?
add port and polish, some nice rocker/spring kit, and a more aggressive cam
then adjust fuel system
walbro pump, adjustable pressure regulator and maybe some better injectors.
followed with a tune at the end
Also, maybe some higher compression pistons or different rods.
please let the ideas flow.
And before we go there, i understand this might be a horrible idea and could end badly - but i just want to learn a bit and throw ideas around. maybe it will work out.
Old Feb 23, 2010 | 05:34 AM
There is no other GM engine that could provide heads that would work on the 4.3L v6.
About the best article for getting N/A (naturally aspirated) power out of the 4.3L v6 was entitled "The 3/4 350" and was run in one of the more main stream hot-rodding publications. A quick search here or on google should turn up the article.
Old Feb 23, 2010 | 06:29 AM
yeah, i have scene it and its a good article - i was just curious and wanted to see other options is all. thanks swartlkk, you always have the answer.
ComputerNerdBD
Oct 15, 2013 12:03 PM
kevlar974
Jul 11, 2011 05:01 PM
old skool luvr
Jan 24, 2010 01:10 AM
gohan69
Feb 6, 2008 06:48 PM
swisstom
Jul 3, 2006 12:39 AM
