1995 Blazer transfer case vacuum switch.
Old 03-11-2012 | 06:57 PM
Nicholas Smeed Jr.'s Avatar
Nicholas Smeed Jr. is on a distinguished road
Default 1995 Blazer transfer case vacuum switch.
My electronic 4 wheel drive hi and lo lights will not come on when I push the buttons. I checked the fuse and it's good. Will a bad transfer case vacuum switch and or hoses cause my lights not to come on and the 4 wheel drive system not to work?
Old 04-02-2012 | 01:06 PM
roadrageblp46254's Avatar
roadrageblp46254 is on a distinguished road
It might just be the light bulbs behind the switch
Old 04-02-2012 | 01:56 PM
50lb_cat's Avatar
When you push the button can you hear any click from behind the passenger side dash? You can pull your battery to start with. The vaccum actuator is under the battery tray. Look for tears in the diaphram and check the lines going back to the transfer case.
However, if you push the botton, hear a click but no light comes on that would lead to a bad selector switch. Or if the lights come and go. There is a great write up of diagnosing the system in the DIY section.
cjb2145
18
10-06-2018 05:46 PM
scphill34
04-05-2013 10:52 PM
kenlani
02-11-2013 07:32 AM
paulp64131
12-26-2011 04:52 AM
Chevy33
01-09-2011 08:26 PM
Quick Reply: 1995 Blazer transfer case vacuum switch.
