1996 transmission change?
Old Apr 15, 2006 | 12:41 PM
mjjrkb's Avatar
mjjrkb is an unknown quantity at this point
Default 1996 transmission change?
I have 1996 s10 blazer 4wd with a bad automatic transmission, I would like to know if a transmission from 1998 will work in my blazer?
Old Apr 16, 2006 | 05:03 AM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
Default RE: 1996 transmission change?
yes as long as your 98 is a 4wd also if not then the output shafts are different lengths so your outa luck
Old Apr 17, 2006 | 03:02 PM
Hanr3's Avatar
What he said, although there are ways to make a 2wdr unit work. Requires swapping the output shaft of the tranny.
You can find a 4L60E from many donor vehicles. Fullsize trucks/Suvs 1/2 ton down in size will ahve a replacement 4L60E, as long as its 4wdr. The fullsize ones are a little stronger then the S10 ones from the factory.
Hormisdas
Nov 27, 2012 09:42 PM
roddy
Jun 28, 2012 04:52 PM
blazer_123
Jan 5, 2010 10:11 AM
john01blazer
Jun 19, 2008 04:39 PM
KA3AX
Nov 21, 2006 04:59 PM
