2.8L engine performance
Old Jan 20, 2010 | 05:03 PM
drogg1's Avatar
drogg1 is on a distinguished road
Default 2.8L engine performance
I have a 1985 Chevy s10 Blazer with a 2.8L V6. It's stock as can be and I was wondering if anyone had any suggestions performance wise. Is it worth doing anything at all to a 2.8l? Also, where are some places I can find performance parts for the 2.8L besides Summit?
Keep in mind that I am pretty knowledgeable when it comes to cars/things mechanical.
Any help/advice is appreciated.
Thanks
Old Jan 20, 2010 | 05:05 PM
Not worth the effort to even think about it.
The best upgrade you'll get is with a motor swap to the 3.4L v6 from a Camaro/Firebird.
Old Jan 20, 2010 | 09:28 PM
neo71665's Avatar
Depends on what you wanna do. Most every upgrade you can do to the 2.8 will swap over to a 3.4 if you do decide to go that route later on. Saying its not worth the effort is in the eyes of the beholder because of this. Its not like you are just throwing money at it on parts you will never be able to use again.
You being carbed the first thing I would suggest it ditching the problematic 2 barrel on it for a decent aftermarket one. This will require a new intake and unless you are extremely lucky and find one of the ones no longer made Eldebrock is the only option.
They make headers and cams for a 2.8. Also swapping out your rocker arms to 1.6 (roller or non) will wake it up a bit.
If you really wanna get into it, swapping heads to the 86+ off of a fuel injected 2.8 will help.
If you really wanna look in to doing work on it without being harrased by people telling you to not waste your time or throw a 350 in it I have a few s-series and 60 degree engine forums that are more friendly. Just shoot me a PM
Old Jan 20, 2010 | 09:32 PM
bigkhans's Avatar
bigkhans is on a distinguished road
So how would a weber work out?
Old Jan 20, 2010 | 09:55 PM
neo71665's Avatar
Personally I don't care for them but there are guys out there that do like em. Once tuned they run fine I guess but can be really picky on tuning.
Old Jan 20, 2010 | 10:15 PM
drogg1's Avatar
What cars and year models did the 3.4L come? Is it a direct swap?
Do you mean upgrading to an aftermarket 2 barrel or 4 barrel? I would think even the smallest 4 barrel would be a little large. Also, what aftermarket brands do you recommend specifically?
What sort of power gains should I roughly expect out of headers?
When upgrading to an aftermarket cam, do I have to worry about too much lift with the stock valve springs?
Would rocker arms with a cam also have any valvetrain issues?
Also, is it cost effective to do all of these things versus finding a cheap small block V8 or 4.3l V6 and swapping them in? I suppose I should crunch my own numbers but I'm curious if it was known off-hand.
Thanks. Any advice is helpful even if it is to say that the 2.8l is a dog.
Old Jan 21, 2010 | 02:25 PM
Mczuk's Avatar
Mczuk is on a distinguished road
The advice I got back when I had my 84 s-10 was to swap in a 2.8 from a camaro, they came with more power from the factory 115 for the truck and 140 I think for the camaro. Never got around to it though so I can't verify.
Old Jan 21, 2010 | 05:25 PM
Phil's Avatar
My cousin has a 2.8 in his 87 Camaro. I don't think it even has 100hp from the times I've driven it lol.
Old Jan 21, 2010 | 06:19 PM
neo71665's Avatar
drogg1, to answer your questions in order:
93-95 camaros and firebirds.
http://members.shaw.ca/betterthanyou...ine%20swap.htm
2 or 4, holley makes a 4 barrel thats under 400 cfm (390 if I recall) that will work. Personally I would stick with a 2.
About the same as any other engine. Hard to put an exact number cause there are so many factors that can screw with the outcome.
yes, just like with any other engine
yes just like any other engine
I wouldn't waste my time with swapping a 4.3 in where a 2.8 was. Too much of a headache for only gaining about 10 HP over the direct swap 3.4.
Horsepower 125, Torque 150 for s-series and Horsepower 130, Torque 160in for the f-bodies 1987.
Much better off putting a 3.1 or 3.4 out of a f-body vs just putting the same engine (2.8) back in it. Only difference was cam and fuel injection setups on the 2.8s in f-bodies Not big enough power gains to justify swapping out the engine when you can put the f-body cam in a s-series easy enough.
lowmiles
Engine & Internal
Jul 7, 2010 01:30 PM
pink45
Jun 15, 2010 08:57 PM
95 S10 Blazer
Jun 29, 2009 07:16 PM
Halflifezr2
Engine & Internal
18
Jan 7, 2005 01:30 AM
01xtreme
Engine & Internal
Sep 24, 2004 06:01 AM
