4.3 head gasket relacement ?
Old Mar 24, 2006 | 06:53 PM
halftrack's Avatar
halftrack is an unknown quantity at this point
Default 4.3 head gasket relacement ?
my 4x4 4.3 1991 s-10 blazer 2 dr blew a head gasket so im going to try to fix it, what other parts should i buy other than gaskets, and what else should i look for when replacing the gaskets. Is there a manual out there that has the torque values or is step by step on how to replace the gaskets
thanks: Matt
Old Mar 24, 2006 | 11:43 PM
4lowlife's Avatar
Default RE: 4.3 head gasket relacement ?
Yep. Haynes auto repair.
Old Mar 25, 2006 | 01:45 AM
tom1337's Avatar
tom1337 is an unknown quantity at this point
It is kind of hard to describe the steps but a factory service manual would help you greatly. If you only need torque settings then a Haynes manual will do.
The things you should look for are cracks and/or warping on the head and block. Bad cracks you can see. For small cracks there is a blue liquid (for the life of me I can not remember the name) that can be used. But I guess you would only really concerned with big cracks. Warping can be checked with just a straight edge. If you have either a big crack or warping you will need some machining or in worst case a new engine.
Additional parts you might need: I personally would replace any connecting bolts with new ARP bolts (just in case they were stressed which might cause them to break when torqued ) but you can probably get by with the old hardware. You should get some thread sealant - there might be some bolts that have to be sealed off when assembled.
Before assembly clean and inspect the head (valves, valve springs, keepers ect) for breaks, missing, or bent components.
After assembly give it an oil change and have the cooling system flushed. You also might want to have a cooling system pressure check just to make sure your gaskets set properly.
Old Mar 27, 2006 | 03:59 PM
Hanr3's Avatar
Take the head to a auto machine shop and have them magnaflux it and check for warpage. Then might talk you into replacing the valve guides and cleaning the head, both are also good ideas. If you do get it cleaned and new valve guides installed, take him both heads.
Haynes manual will work for this repair. There are better service manuals, however the Haynes manual will work.
While you have the head(s) off, notice how clean or dirty the pistons are, clena them up some. Keep them covered so the walls don't rust. Srapy them with oil (WD-40) so nothing rusts.
This is what my sons 4 banger engine looked like after I pulled th head off. He also blew a head gasket. Cost me $80 at the machine shop to have it magnaflux, cleaned, and new valve guides installed.
Old Mar 27, 2006 | 04:11 PM
Magnaflux == check for cracks.
You should atleast have the heads fly cut to see if they are warped at all. Shouldn't be much to have a machine shop do this. If you have some extra cash laying around, drop the valves out and check them for wear. If none is present, re-lap them and call it good. If you see excessive wear, have a valve job done now. You'll regret it if you have to pull them off again because you are having trouble sealing the valves.
Old Mar 27, 2006 | 06:20 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
and for the love of god replace your valve seals if you don't they will surely start leaking oil with a week....never fails
limited edition 1
Jan 27, 2023 11:07 AM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
rafa.jrbarajas
Jun 28, 2009 03:12 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
