4.3L performance suggestions?
Old Jan 12, 2011 | 10:31 PM
  #21
matt92's Avatar
matt92 is on a distinguished road
Yeah, were forced to.
Old Jan 13, 2011 | 09:38 AM
  #22
zedartwo's Avatar
the 6.0 has lower compression which makes lots of room for superchargers or turbos but If your going naturally aspirated then its really up to what you can get out of each.
Old Jan 13, 2011 | 10:05 AM
  #23
Longer02's Avatar
Longer02 is an unknown quantity at this point
Depends on what 6.0 you are talking about. The LQ4 has the lower compression ratio due to it's dished pistons and the LQ9 has higher compression since it has flat tops.
I would ****** up a 5.3L for sure (can be had complete for as little as $500) and throw in a nice cam and aftermarket heads on it. Should be close to 400 rwhp with that setup.
Old Jan 13, 2011 | 10:09 AM
  #24
zedartwo's Avatar
Yea true. It all in what your looking for!
Old May 15, 2011 | 07:41 PM
  #25
travisrussell88's Avatar
travisrussell88 is an unknown quantity at this point
would these be a good idea for moderate performance gains, a v8 would be best but gotta wait a few years. so would these be good?
http://www.gmpartsdirect.com/perform...CATID=304.html
Edelbrock 3713 - Edelbrock Performer 4.3L T.B.I. V6 Intake Manifolds - Overview - SummitRacing.com
Hedman Hedders 69410 - Hedman Street Hedders - Overview - SummitRacing.com
with new valvesprings, rockers, pushrods, lifters, timing chain, gaskets, and y-pipe
Old May 16, 2011 | 02:21 AM
  #26
peoples8's Avatar
peoples8 is on a distinguished road
Talking 2001 4.3 Vortec
Hi, I have a 2001 Chevy Blazer Xtreme, 4.3l vin W. I have a .510 lift Crower cam, Comp Cam hydraulic rockers and lifters. I've also have the heads ported and polished, etc, with 1.60 stainless intake valves, and 1.94 exhaust. I've also put a huge Turbo kit, the largest single turbo, on Ebay. I'm looking @ 400hp + when I get a chance to get it tuned. Right now its unreal! Can't wait to have it tuned. You can gain well over 300hp if you have the proper work done and have it tuned correctly. I'll have around $2000 extra in it when I'm done. Just saying theres no need for a V8, if you take the right route.
Old May 16, 2011 | 09:10 AM
  #27
matt92's Avatar
wow, this gives me and travis hope! Is there any extra work needed when installing that cam and lifters? ex: valves?
Old May 16, 2011 | 01:16 PM
  #28
^what he said
Old Jun 5, 2011 | 10:19 PM
  #29
Okay, so i'm thinking about doing this: A rebuilt LB4 short block with 4-bolt mains, 9.5:1 pistons, forged rods, new crank, 1996+ true vortec heads, beehive valvesprings, hardened pushrods, new lifters and rockers, comp cams 270ahr, msd ignition system, edelbrock dualplane manifold with tbi adapter or tbi manifold for vortec heads, spectre modular cold air intake, new timing chain and cover, new valve covers, felpro gaskets, arp bolts, high flow fuel pump, bigger injectors, long tube headers through a custom y-pipe, high flow cat and muffler (single in dual out), beefed up t-5 trans, trac-bars in rear with P275/60R15 BFGs out back and P235/70R15 BFGs up front.
Desktop dyno spits out 321hp at 5500rpm 323lbs. ft. at 4500rpm with just the cam, vortec heads, 9.5:1 compression, dual plane manifold and small tube headers. 329hp at 5500rpm and 331lbs.ft. at 4500rpm with single plane-std flow. 330hp at 5500rpm and 334lbs.ft. at 4500rpm with single plane-high flow. 320hp at 5500rpm and 332lbs.ft. at 4000rpm with SFI (found on newer 4.3L-updated spider that injects sequentially instead of simultaneously like previous versions).
maybe boost it...vortech v4-t s/c gets me 468hp at 6500rpm and 401lbs.ft. at 5000rpm. garrett t-51 54-3 gets me 425hp at 6500rpm and 375lbs.ft. at 4500rpm @ 18psi (rpm limited to 6500, makes more hp up to 8k) I'd go with s/c personally
Sound good?
williamapocalypse
Performance & Brainstorming
Jan 4, 2011 01:17 AM
lowmiles
Engine & Internal
Jul 7, 2010 01:30 PM
Halflifezr2
Engine & Internal
18
Jan 7, 2005 01:30 AM
thorbergdt
Engine & Internal
Jan 5, 2005 10:02 PM
01xtreme
Engine & Internal
Sep 24, 2004 06:01 AM
