Are 4.3's internally or externally balanced?
Old Nov 3, 2012 | 11:36 PM
brino1's Avatar
brino1 is on a distinguished road
Default Are 4.3's internally or externally balanced?
Title says it all.I can't figure it out
Old Nov 4, 2012 | 12:17 AM
Rottidog's Avatar
Balanced how? They have a internal counter balance shaft for the cam. At least my 2002 & 2004 engines do.
Old Nov 4, 2012 | 09:58 AM
brino1's Avatar
I'm doin a 4.3 swap in a Toyota truck and I need to run a 153 tooth flywheel.they sell internally and externally balanced flywheels.so I guess is the crank shaft balanced?I believe the motor I have is a 95.its got the big intake manifold.
Old Nov 4, 2012 | 10:48 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default 4.3 balance shaft
Has been used since 1992 and up.The engine had an internal balance problem because of the 90* block design and the way it fires.Its either odd fire or even fire cant remember exactly.The balance shaft was to cure the internal vibration.
The crankshaft in externaly balanced hince harmonic balancer on the front.The flywheel is also balanced.
Hope this helps.
grwarren
Jun 20, 2013 12:47 PM
Karcinagin
Tires and Wheels
Apr 15, 2013 06:11 PM
cc4usa
Jul 30, 2011 02:21 PM
blazinchevy89
Tires and Wheels
Mar 7, 2010 01:30 PM
grendragginbu
Oct 11, 2007 04:32 PM
