Wheel not staying balanced?
Old Apr 9, 2013 | 04:54 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
Default Wheel not staying balanced?
So I just lifted my truck and put on steel rims that I sand blasted and painted black. Had my uncle mount and balance the wheels and they balanced just fine. Note the tires were used on my dads full size 74 and do not have 500 miles on them. Took it on the road and then vibrations. So went back to his house and we balanced them again. They were balanced using a cone in the hub hole in the rim. Drove it again and more vibrations. I maked the tires before I came home from work today and got on it a few times(1-2 shift is quite firm) and the tires did not spin on the rim.
Any ideas? Should they be lug-centric balanced?
My next step would be to have them balanced on a road force balancer.
Old Apr 9, 2013 | 10:30 PM
00chevblazer's Avatar
00chevblazer is on a distinguished road
Have you considered having a bent wheel perhaps? I know you said they are fairly new, but wilder things have happened.
I they should be hub-centric balanced if im not mistaken.
Old Apr 10, 2013 | 06:04 AM
Karcinagin's Avatar
I dont think its bent, I took all the rims and spun them on the tire balancer and the most movement i saw at 1/8 of an inch on one of the rims.
Old Apr 10, 2013 | 07:22 AM
LeWhite's Avatar
Lets see, you modifyed your suspension now you have probs. Id guess if you put back the stock rims your problems would cease. Because the new rims are not hub centered
Old Apr 12, 2013 | 10:05 AM
Karcinagin's Avatar
Originally Posted by LeWhite
Lets see, you modified your suspension now you have probs. Id guess if you put back the stock rims your problems would cease. Because the new rims are not hub centered
Don't you mean stock suspension? As for the rims I check and they are hub centric rims, they came off a 4x4 s10.
I am going to bet the tires have flat spots from sitting 6+months and not moving so I am going to drive it some and then balance it again and see if they are better.
Old Apr 12, 2013 | 02:49 PM
LeWhite's Avatar
Try spin ballance. Bubble ballance doesnt account for wobble or out of plane ballance. I'v never heard of a flat spot from setting dismounted.
Do you have a bent axle?
How did you get your shifts so firm?
Old Apr 14, 2013 | 05:27 PM
Karcinagin's Avatar
They were on rims under my dads 74 full size sitting. I would say axles are fine, as no vibration with stock rims and winter tires on them.
Old Apr 15, 2013 | 06:11 PM
LeWhite's Avatar
Again we go you modifyed your suspension now you have probs. You un modify and the probs will go away. Hmm.
brino1
Engine & Internal
Nov 4, 2012 10:48 AM
cc4usa
Jul 30, 2011 02:21 PM
rasputinlv
Nov 10, 2010 07:53 PM
blazinchevy89
Tires and Wheels
Mar 7, 2010 01:30 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
