blazer upgrades
Old Jun 3, 2013 | 01:55 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Post blazer upgrades
Im gonna add 4.11 youkon gears, bored throttle body, comp cams and valves, k&i cai, flowmaster 40 series. Im gonna need some more power because im gonna add a 2 inch bodylift and 31 all terrain tires. would all this stuff give me enough power not to loose alot of mpg with the 31s?
Old Jun 3, 2013 | 02:44 PM
slcblazer's Avatar
slcblazer is on a distinguished road
The gears, lift, and tires arent going to help much with gaining MPGs.
I would think you might even out.
Old Jun 3, 2013 | 03:02 PM
01blazer16's Avatar
im not gonna put the gears on it anymore but how much mpg would i loose if im at 17 stock right now?
Old Jun 3, 2013 | 03:24 PM
slcblazer's Avatar
well the bigger tires, the lift would take it down a few. the CAI may take it up one or two along with the exhaust, add in a highflow cat too.
Old Jun 3, 2013 | 04:23 PM
01blazer16's Avatar
I might get one because my truck looks like someone drove it under water as much rust as it has under it. Will it sound better with a highflow cat on it?
Old Jun 3, 2013 | 05:24 PM
chris015's Avatar
my old blazer was getting 17 mpg with oem size tires(27"ish). i went to 30" and lost 2 mpg.
with 31's,you might be ok. Actually,what gears do you have right now? If you look in the glove box,youll see a big sticker with 3 letter/digit codes. find the gu codes. it'll be like gu1,gu2,gu3,etc. list it and i can find what you have if you dont know.
Old Jun 3, 2013 | 05:35 PM
01blazer16's Avatar
i have 3.42 gears right now but when i get the 31s im gonna put 3.73 in it
Old Jun 3, 2013 | 07:15 PM
LeWhite's Avatar
Cai wont increase mpg bigger tires definately will make your milage worse as will a lifted vehicle. Making more power will result in more fuel used.
Old Jun 4, 2013 | 09:18 AM
01blazer16's Avatar
I know that I'm just gonna put bigger tires to make it look better
Old Jun 4, 2013 | 12:18 PM
LeWhite's Avatar
OPEC loves you.....and your 31s
chitown906
19
Oct 4, 2013 01:54 AM
Aj Stachowicz
Dec 10, 2012 09:32 AM
ryguy013
Aug 23, 2012 10:37 PM
BlazerGuy2001
Sep 17, 2009 11:17 PM
TheBrettster
Mar 30, 2008 05:12 PM
