Blown 4.3 swap. What do I need?
Old Feb 24, 2010 | 12:18 PM
willtoskie's Avatar
willtoskie is on a distinguished road
Default Blown 4.3 swap. What do I need?
Last month I blew my engine in my 96 blazer at only 89,000 miles! I'm going to do a swap for a rebuilt 4.3. Besides mounts, hoses, and fluids, what else do I need?
Old Feb 24, 2010 | 12:22 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
Are you getting a long block. if so, you will need intake gaskets, exh gaskets and so on. A few of us have done this so if you run into issues let us know. We will point you in the right direction.
Old Feb 24, 2010 | 08:24 PM
willtoskie's Avatar
Yeah it's a long block. What are some problems you've run into?
Old Feb 25, 2010 | 09:09 PM
samuknow's Avatar
Mostly the bell housing bolts are a real peach to get to. Get the entire truck as high off of the ground as possible. That will give you some room. Long extensions will be a big help. The upper driver side bolt is next to impossible. Dropping the trans cross member and tipping the engine back to reach it with a long extension or jacking up the body a little will wok. I took the shortcut and drilled a hole under my accelerator pedal to reach it. Filled it when I reinstall the engine. Use zip lock bags for bolts and hardware. Label everything. The AC will lay over the side. By new motor mounts. You will already be there so might at well. Pictures will help also. I will check back. Feel free to ask as you go. Good luck.
limited edition 1
Jan 27, 2023 11:07 AM
98Ltblazer
Nov 21, 2010 02:24 PM
IABlazer
Nov 21, 2006 12:18 AM
oldsmobuick420
Nov 19, 2005 04:30 PM
yzf125
Oct 6, 2005 03:31 AM
