CEL
Old Oct 19, 2006 | 12:17 AM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
Default CEL
My CEl came on tonight so i went over a buddies and checked it it said it was the heater core sensor or sumthing like that then high volage anyone have anyclue what this means
Old Oct 22, 2006 | 10:00 PM
Hanr3's Avatar
Default RE: CEL
Did you ever get ananswer?
Did you figure it out?
Old Oct 23, 2006 | 12:13 AM
mudsliner's Avatar
Default RE: CEL
no never figured it out heat woks good and everything else is workin but if i leave my heat on for a while i get a burnt smell after a while i need to figure it out casue winter comein up quick
Old Oct 24, 2006 | 12:26 AM
mudsliner's Avatar
Default RE: CEL
i was talkin to my teacher at voca where im takin auto tech and he siad that it has sumthin to do with the o2 sensors
Old Oct 28, 2006 | 08:42 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Default RE: CEL
The O2 sensors have nothing to do with the heater core. Sounds to me like the code may refer to the temp control - or even a fan motor or fan speed switch overheating. When you run the heater, press your hand onto the fan speed switch - and do your best to trace that burning smell. The heater core is front and center in the dash.
It happens that I have a '97 and the two-volume factory service manual (soon to be for sale, I'm trading the car no later than Christmas and won't need the manual after that). Section 1A-2 describes the unit operation - there is reference to a temperature valve that moves toward and away from the heater core to allow more or less cool air to flow through. I'm not sure whether that's the part your code referenced.
What IS the code you got?
Old Oct 28, 2006 | 09:24 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: CEL
Absolutely NOTHING on this HVAC system will set a CEL...you're chasing the wrong animal! Take it to Autozone and have them scan it for you (it's free) then repost with the code number and we can help you out.
Old Oct 29, 2006 | 09:40 PM
mudsliner's Avatar
Default RE: CEL
i have it written down somewhere i jus got to find it
SPLjimmy
Dec 5, 2008 03:07 PM
hebelracing38
Nov 2, 2008 04:13 PM
jman_08
Jun 25, 2008 07:27 PM
hoffyinaz
Sep 5, 2006 01:24 PM
meglog
Mar 28, 2006 04:38 PM
