eng
Old Oct 11, 2011 | 05:19 PM
Yankeefan744's Avatar
Yankeefan744 is on a distinguished road
Default eng
I have a 02 s10 blazer and was wondering if I could use a 4.3L V6 out of a 99 s10 blazer? how could i tell? or does anyone know?
Old Oct 11, 2011 | 05:26 PM
There are a few differences, but most can be easily accounted for. The one that will get you is the knock sensor mounting. On your 2002 engine, the KS is bolted on with a somewhat small metric bolt. On the 99, it will have a threaded in KS that attaches via a tapered pipe thread. The two types of knock sensors are not compatible so you would have to find some way of filling the hole & then drilling/tapping whatever you use to fill it for the same metric thread as the bolt your 2002 block uses.
Old Oct 20, 2011 | 12:34 AM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
If you have a late model 2002 (like mine), it doesn't have an EGR valve. You would have to figure out how to wire / hook that 99's into your system in that scenerio.
Old Oct 20, 2011 | 03:19 AM
DySfUnCtIoNaL's Avatar
DySfUnCtIoNaL is on a distinguished road
^^You would have to get you're PCM tuned to turn off the EGR valve.
Old Oct 20, 2011 | 06:34 AM
pettyfog's Avatar
Putting an EGR engine into a non-EGR car, just block off the passages.
Starter Guy
Dec 13, 2009 08:30 AM
chitowncruiser
Nov 28, 2009 08:03 PM
rick nielsen
Engine & Internal
Oct 14, 2007 03:41 AM
arbowman
14
Jul 9, 2007 07:11 AM
arbowman
Mar 29, 2007 11:46 PM
