engine compatiblity
Old Jan 27, 2007 | 11:22 AM
Monkey4Life's Avatar
Monkey4Life is an unknown quantity at this point
Default engine compatiblity
I have a 93 s10 blazer w/ the Vortec v6. Unfortunatly, the crankshaft bearing has been shredded[:@]. Would it be easier to swap a junkyard engine, or try to fix it? If i have to swap can I use the nonVortec v6?
Old Jan 27, 2007 | 06:39 PM
91 Streeter's Avatar
91 Streeter is an unknown quantity at this point
Default RE: engine compatiblity
either way your gonna have to pull your motor. and you should be able to use a non vortec motor
Old Jan 28, 2007 | 04:08 PM
I figured I would have to pull it...I can get a junkyard tbi v6 for $400, and I have a garage to work in. now the question of affordability enters the picture. would it be cheaper to replace or fix the engine?
Old Jan 28, 2007 | 04:16 PM
On the replace or repair, it all depends on the extent of the damage and the repairs required. If it were me and the crank wasn't damaged too much, I would have touched up and then do a full rebuild on the motor, heads and all. Then you know exactly what you have. With a junkyard motor, unless you go through and rebuild it or atleast tear it down, you really have no idea what you're putting into your truck.
Old Jan 29, 2007 | 08:52 PM
Can I pull and rebuuild it for less than $500? Thats not getting it bored out, and keeping as much as i can...this would also be my first rebuild...so I would be taking my time. At this point its been sitting for almost a year now.
Old Jan 29, 2007 | 08:55 PM
oh yeah, I drove it for 10 miles like that...
fvb72
Jan 17, 2011 11:33 AM
N.alaska_blazer
Feb 23, 2009 01:31 PM
johinut
Oct 24, 2008 04:06 PM
loppy crimp
Sep 11, 2008 08:31 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
