External oil filter and lines
Old Oct 6, 2012 | 09:14 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question External oil filter and lines
Does anyone know if they make an adapter for where the external oil lines connect to the engine so that the oild filter can screw on directly to the bottom of the engine.Also I need a pic of the 2 bolts that hold it in place if anyone can show me what they look like.Thanks
Old Oct 6, 2012 | 11:38 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Here is the bolts that hold the oil filter onto the core support if thats what you wanted.
And what year jimmy do you have?? If its newer then you have a oil cooler and you would have to bypass it. Why do you want to do this??
Old Oct 7, 2012 | 08:43 AM
chris015's Avatar
from checking his other posts he has a 96.
Old Oct 7, 2012 | 10:48 AM
97 Cherry can you take a pic of the bolts that hold the external adapter to the engine.Also to answer your question I did not know that setup had an external oil cooler so I guess I will leave that alone.Thanks for the info.
Old Oct 7, 2012 | 11:49 AM
kabrynsdaddy's Avatar
kabrynsdaddy is on a distinguished road
You can use the plate off a 350 to have your oil filter on the side of the block but if its 4 wheel there ain't enough room cause you Will need a ph5 filter
Old Oct 7, 2012 | 04:43 PM
Thumbs up
I have had this project taken apart for so long that I had forgot the lines go into the radiator.Anyways I was able to reconnect everything back together the right way.
ve3nsv
Aug 8, 2011 08:56 AM
subarugt06
Mar 6, 2011 11:21 AM
ethan.zick
Mar 16, 2010 12:43 AM
Ugly_Monkey
Feb 25, 2009 09:02 PM
vassago41301
Jan 26, 2007 03:58 AM
