gas mileage
Old Apr 23, 2006 | 12:18 PM
Nomad76lj's Avatar
Nomad76lj is an unknown quantity at this point
Default RE: gas mileage
it could be tranny fluid if its leaking at the rad if it dosnt have an added on tranny cooler it goes through a cooler in the rad and it could be leaking there.
Old Apr 23, 2006 | 09:57 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
so it is def coolant and it is leaking from the front of the radiator where i cant see it...and then seeping around on the groves that go along the radiator and then dripping down
Old May 5, 2006 | 10:10 PM
geekdagr8's Avatar
geekdagr8 is an unknown quantity at this point
i have a 2000 chevy blazer and im lucky to get 11 miles per gallon....mine is a gas hog...is it hard to change O2 sensor?
Old May 6, 2006 | 03:56 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
gas mileage is also greatly affected by how much you put your foot into it. if you drive slower, at lower RPMs, than youll use less fuel.
low tire pressure can increase the rolling resistance, decreasing your gas mileage
a few other things:
1. dont accelerate toward red lights, i see so many people do this, its a pure waste of gas, and you just end up getting on the brakes harder. instead coast up to the light (sure, youll get to the light slower, but youll be right next to that other person) you also cause less wear on your brakes by coasting, as you generally slow down when coasting.
2. coast down hills, if its steep enough for you to continue at the speed limit, theres no point in being on the gas
3. dont leave the engine sitting idling for a long time, just turn it off. a myth is that it takes more fuel to shut it off and restart, this is not true
i get about 16 in the city and 20-21 on the highway in my 95
yzf125
Apr 29, 2007 01:17 AM
BlaZeR FXB1581
Engine & Internal
Oct 13, 2005 01:30 AM
RedBlaze
Aug 2, 2005 10:03 PM
2001Blazer4x4
Engine & Internal
Aug 1, 2005 01:23 PM
SEDOC
May 26, 2005 05:46 PM
