Heater Core Replacement
Old Apr 3, 2007 | 07:14 PM
adagna's Avatar
adagna is an unknown quantity at this point
Default Heater Core Replacement
I have my repair manual that gives a step by step of changing out the heater core. I was wondering if any of you have done it before and if there are any short cuts as it seems like I have to remove a large number of screws a couple of connectors and basically the entire dash. Are there any tricks to make it easier? I have a 96 S10 with the 4.3L V6 if that helps.
Old Apr 3, 2007 | 08:00 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: Heater Core Replacement
The only trick is to accept that you do have to remove the entire dash, andyou will probably never find an easier dash to remove! Well actually the '98-2005 dashes in blazers are the easiest, but the '94-'97 is a close second. Just don't try to loosen it and sneak things by, it's less time-consuming to just remove it...take your time and remember where each screw goes and the order in which you remove them...it will be a breeze. If you do get into a jam...post up, I've had dozens of these out and It really is not bad.
Old Apr 4, 2007 | 11:07 AM
blazinloud's Avatar
its alot of work......and very expensive to have a shop do it.
DrEaMsTeVe
61
May 8, 2011 05:48 AM
DrEaMsTeVe
Oct 19, 2009 10:44 PM
brinriha
May 18, 2007 06:30 AM
wilds_dog
Oct 29, 2006 03:45 PM
insertcreativenamehe
Mar 1, 2006 10:43 AM
