Info about blazers. . .
ORIGINAL: lastcoupe
a-tack...I was just looking on line for this stuff, but if you want your truck's specifics...I do have access to G.M's database lol. I can tell you EVERYTHING about your specific truck if you want...just PM me your last 8 digits of the VIN and you won't believe the stuff you will find out! I can even give you a complete claim history for all repairs/recalls done by dealers and when and where it was purchased litterally everything. And it will decode every option that you have...maybe even which fleet purchased it, most likely a rental car though.
ORIGINAL: Zygoat
so from what ive read above the zr2s all came with a limited slip in the rear, and the insta trac comes with a locker up front. is this right, and how would i tell?
Limited slip is not a locker...see other current post......and those are rear axles...not front ones. A limited slip axle is a G80 option code and it is what is refered to by most people as a "posi" A locker is completely different, there IS NO SLIP in a locker no "differential" meaning there is noability for the tires to turn at different speeds like they do around corners (all corners). That's why a welded axle will hop and squeal around a corner...the axles are forced to turn at the same speed and the out side tire needs to turn faster than the inside tire (and vise versa).
i know the diffrence between posi and lockers and i know that the posi would be found in the rear but the quote above said their was alocker in the front. i know these are two seperate things. from what you are saying the posi was an option for the rear do you know if this was part of the zr2 package or is it seperate.
