intakes
Old Feb 4, 2007 | 12:29 AM
Jimmysls98's Avatar
Jimmysls98 is an unknown quantity at this point
Default intakes
what are good intakes from ebay and are they supposed to connect to the manifold?
Old Feb 4, 2007 | 12:15 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default RE: intakes
Ok well this is the one I have been looking at for a while. It has the heat shield to make it a cold intake, and it has a longer filter to offer a little bit better air flow.
Click Me
Old Feb 4, 2007 | 04:07 PM
tippmann243's Avatar
tippmann243 is an unknown quantity at this point
Default RE: intakes
a stock hacked air box with a drop in filter will give you the same gains as a high dollar aftermarket air intake
Old Feb 5, 2007 | 05:25 AM
20Blazer00's Avatar
Default RE: intakes
Unless these "heat shields" actually contact the hood and completely seal off the air cleaner they are not as efficient as a well modified stock air box...
Old Feb 5, 2007 | 05:08 PM
blazinloud's Avatar
Default RE: intakes
reeeeealllly? thats the 1st time i heard that one..........Is the point not to draw air from as far from the engine as possible......such as bending down by the headlight? and wouldnt the increased time to travel to the engine cool it a little more? and isnt the stock intake rippled, restricting air flow?
Old Feb 5, 2007 | 07:19 PM
Default RE: intakes
If you look, the acordian section of the pipe, is actually a lot larger than the 'restrictions' in the pipe. Actually, the largest restriction in the intake path is the throttle body itself. I did a little analysis of this a long while ago and the throttle body with the stock deflector was the smallest part of the intake. Without the deflector, the pipe at the front of the air box now becomes the smallest point, however, it is designed as a venturi and will flow quite a bit more than a pipe with a diameter equal the smallest diameter in the venturi.
Its all about getting nice, dense air. The cooler the air, the more dense it is. The air being pulled through the radiator can be over 170*F on a hot summer day with the A/C giving its contribution of heat. Draw this air into the intake and you are defeating the purpose.
True, a cone filter may drastically outflow the stock panel filter, but is it necessary? Hmm... If you have an open element cone filter in the engine bay, you are eliminating any gain in flow by sucking in hot air.
Old Feb 5, 2007 | 07:37 PM
Default RE: intakes
So basiclly you need to run your intake down to under or near the left lights so it can suck in cold and then but a heat shield around it so no engine heat can play a factor.
Old Feb 6, 2007 | 09:24 AM
blazinloud's Avatar
Default RE: intakes
i dunno how effective a heat sheild will be......prolly more of a marketing gimmik.
Old Feb 6, 2007 | 10:07 AM
Default RE: intakes
Marketing gimic... Yeah... Damn. I knew I missed something in heat transfer and thermodynamics.
Old Feb 6, 2007 | 12:52 PM
Jimmysls98's Avatar
Default RE: intakes
what do you mean by "hacked airbox?" will it save money and put a gain on??
