intakes
Old Feb 6, 2007 | 12:57 PM
Default RE: intakes
I think he is referring to removing the venturi (snorkle) on the front of the air box and cutting a larger hole in it for incoming air. I would suggest that if a larger hole is used, that you should somehow find a way to route it, via some tubing, to the opening in the radiator core support to ensure that it will draw as much outside air as it can.
Old Feb 6, 2007 | 06:45 PM
tippmann243's Avatar
tippmann243 is an unknown quantity at this point
Default RE: intakes
ORIGINAL: swartlkk
Marketing gimic... Yeah... Damn. I knew I missed something in heat transfer and thermodynamics.
correct it is just a marketing gimick. the air is moving throught the intake so fast that there is MINIMAL to no heat transfer for most plastic materials.
Old Feb 6, 2007 | 07:37 PM
Default RE: intakes
Um... Well, yeah, on the intake piping, however, the heat sheild around the filter (which is what I am assuming he is talking about) is of utmost importance. I agree that a heatsheild around the piping is of little consequence.
Old Feb 6, 2007 | 08:23 PM
Jimmysls98's Avatar
Jimmysls98 is an unknown quantity at this point
Default RE: intakes
so i should just cut it and route a piece of pipe/tube to the opening in radiator?
Old Feb 6, 2007 | 10:18 PM
Default RE: intakes
ORIGINAL: swartlkk
sorry i was talking about intake material. i got a little confused earlier
2002XTREME
Performance & Brainstorming
Jan 22, 2008 03:53 AM
Sean Pedro
Headers, Intake, & Exhaust
Jan 8, 2007 12:46 AM
TheGuardian08
Dec 29, 2006 12:52 AM
chevblazer02
Dec 27, 2006 03:44 PM
blaz3r
Oct 22, 2005 09:00 PM
