Low gas milage?!?
Old Mar 19, 2007 | 11:12 PM
infamous's Avatar
infamous is an unknown quantity at this point
Default Low gas milage?!?
hey everyone, for some reason, im getting really low milage on my 1995 blazer (11.4 miles per gallon). Anyone know what might be the cause of my problem? thanks in advance
-infamous
Old Mar 20, 2007 | 02:54 AM
BLK85's Avatar
BLK85 is an unknown quantity at this point
Default RE: Low gas milage?!?
Could be a lot of things. Air Filter, plugs, wires, cap and rotor may need to be replaced. Could be inproper tire preasure. I would try the easy ones first. Also if its cold out and you let it warm up longer that could also be part of it. All winter I was getting 14 mpg consitintly now that it started warming up Im getting 16 consitently and have gotten as good at 19.
Old Mar 20, 2007 | 06:37 AM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
i installed a remote start( part of my alarm system) it is awsome on those cold winter days
Old Mar 30, 2007 | 05:50 AM
adagna's Avatar
adagna is an unknown quantity at this point
Mine started getting 15 mph when I was used to around 20, so I took it in to the shop and it ended up being blown fuel injectors. Once those were replaced I got back up to 20+mpg. Its a possibility, though my check engine light was on when it happened.
jdiaz
Sep 26, 2023 11:29 PM
BlazerJenkins
Dec 22, 2013 10:40 PM
bdbrissette
Dec 19, 2011 04:42 PM
ToughRod
Oct 22, 2010 12:17 AM
magnum434
Engine & Internal
13
Aug 17, 2006 01:44 AM
