more HP
Old Dec 30, 2008 | 05:01 PM
mikes87k5's Avatar
mikes87k5 is an unknown quantity at this point
Default more HP
Well I have taken the a/c unit off, and my next step is to put on an 8 bladed electric fan I ordered from my lmc truck catalog, but the belt attached to the fan pulley is attached to a pulley that I am unaware of its purpose. It has a hose that runs out of the top back part that runs into some kind of unit. (emissions maybe I don't know) I was wanting to know any issues I might have when I take the belt off and that pulley is no longer running.
Old Dec 30, 2008 | 05:07 PM
rriddle3's Avatar
Default RE: more HP
If you put your vehicle information into your signature, it will help folks know what you're working on.
Old Mar 25, 2009 | 06:54 PM
BuckingBullMan's Avatar
BuckingBullMan is on a distinguished road
its in his signature
Old Mar 25, 2009 | 07:04 PM
Considering that the suggestion was made at the end of 2008, one could assume that the OP took the suggestion and added it... Did you have anything else to add to this thread, BuckingBullMan, or did you just want to pick...
As far as the question regarding the thing behind the pulley with hoses, etc... That is likely the smog pump or air pump. It pumps fresh air into the exhaust to increase catalytic converter efficiency. It would not really impact much if you were to remove it although it is against the law to defeat emissions devices.
But removing the belt will cause other problems... For instance, your water pump and alternator will no longer turn...
Chenzo
Engine & Internal
Mar 29, 2011 01:56 AM
dougs10
Dec 14, 2010 03:24 PM
victoryredblazer
Nitrous, Super Chargers, & Turbos
Jul 12, 2005 11:58 AM
Silverfox
Mar 15, 2005 02:51 PM
zero psi
Feb 16, 2005 11:14 PM
