My POS Blazer Won't Turn Over in the Rain
Old Jul 5, 2006 | 03:42 PM
  #21
p_j_robertson's Avatar
p_j_robertson is an unknown quantity at this point
Default RE: My POS Blazer Won't Turn Over
ORIGINAL: VRDriver4l
Id say starter also, the best alternator test is when the car is running disconect the battery if it stays running the alternator is good if it shuts of go to the part store and get a alternator, im sure most people know that though.
The best way to test the altenator is to put a volt meter up to it. disconnect the altenator from the battery line and if it is putting out at least 12V then you are good (depending on the car of course)
Old Aug 25, 2006 | 01:24 PM
  #22
cpdavngr's Avatar
cpdavngr is an unknown quantity at this point
Does it start after it sits there for about 10-15 minutes or so? If so, check out this thread:
https://blazerforum.com/m_20044/tm.htm
Old Aug 27, 2006 | 10:59 PM
  #23
Scar's Avatar
Scar is an unknown quantity at this point
ORIGINAL: PawNtheSandman
Took it to a shop.
Turned out it was the coil.
For those who didn't read it the first time, his problem is fixed, it runs, no problem with his ride. Now on to the new thread that I about to start.
Scar
Old Aug 27, 2006 | 11:22 PM
  #24
ORIGINAL: Scar
Took it to a shop.
Scar
Thank you mister obvious!
Thread locked due to problem corrected.
amp042
Jun 9, 2013 04:29 AM
shotnva777
25
Sep 27, 2011 07:04 PM
bill62
Jan 30, 2010 06:42 PM
mkemu80
Jan 8, 2010 08:25 PM
C@rpaholic
Oct 2, 2009 12:18 PM
