98 blazer won't turn over
Old Jan 8, 2010 | 01:12 AM
mkemu80's Avatar
mkemu80 is on a distinguished road
Default 98 blazer won't turn over
ok i have a 98 ls blazer. I drove it, washed it, drove it to the bank, parked it, and it didn't want to start. when i crank it the starter kicks, the battery is charged but it won't turn over. I called a friend and he called a friend and they suggested starter fluid. sprayed some into the intake and it turned over but wouldn't stay on. i figured maybe low on fuel, i added 2 gallons and tried again and nothing. not sure where to go next. we checked the fuel pump relay on the fuse box and it sounds like its clicking when the ignition is turned. i don't hear the fuel pump, so my question is, where do i go next? is it the fuel pump, the spark plugsm what? PLEASE HELP!!!!! I need my blazer this winter seems like alot of snow here in jersey and blazers don't get stuck. thanks in advance.
Old Jan 8, 2010 | 05:29 AM
leeclark's Avatar
leeclark is an unknown quantity at this point
sounds like the fuel pump. there is a little valve on the fuel line coming up from under the truck. has a black cap on it, take the cap off push it in and see if gas comes out. if none comes out most likely fuel pump.
Old Jan 8, 2010 | 07:56 AM
Really should test the pressure. The presence of fuel does not mean that the fuel is supplied at the proper pressure for the fuel injection system to actually use it. Check out the Tech Article (DIY) section for the proper fuel pump pressure and leak down test procedure.
Old Jan 8, 2010 | 03:32 PM
mkemu80's Avatar
ok lee thanks i checked the lil black cap valve and fuel came out. anymore ideas?
Old Jan 8, 2010 | 06:11 PM
I find myself doing this more and more...
Old Jan 8, 2010 | 06:30 PM
rriddle3's Avatar
This will probably be too technical and involved, but have a read through this post:
96+ Fuel System Diagnosis
Old Jan 8, 2010 | 08:25 PM
mkemu80's Avatar
sorry swartlkk, i will check the pressure tomorrow. problem is i live in a urban city in jersey and the truck is parked in the streets so i have to check the easy things first. but tomorrow i will check the pressure. i could probably do the job myself but no garage to work in so I'm trying to narrow it down as much as possible before mechanics try to rob me.
amp042
Jun 9, 2013 04:29 AM
jsblazer1999
Dec 13, 2010 08:03 AM
bill62
Jan 30, 2010 06:42 PM
C@rpaholic
Oct 2, 2009 12:18 PM
PawNtheSandman
Engine & Internal
23
Aug 27, 2006 11:22 PM
