Need some help on a BBC AWD blazer swap
Old Dec 12, 2009 | 04:09 PM
_Syclone_'s Avatar
_Syclone_ is on a distinguished road
Default Need some help on a BBC AWD blazer swap
Call me crazy, but I am not known for building the everyday run of the mill vehicle. I would like any info anyone may have on swapping in a Big block chevy in a 4x4/AWD S-10 Blazer (82-94). I am going to do this and make it work, just would like any info on anyone that may have done this or tried this already.
Any help or info on this would be greatly appreciated.
Thank you
Will
sendhere@insightbb.com
Old Dec 13, 2009 | 07:55 AM
_Syclone_'s Avatar
Anyone? I know a BBC will fit. I can weld and fab about everything including my own custom exhaust. I have two worries that I see so far I keep reading about.
  1. The steering column
  2. The oil pan fitment around the front differential.
Old Dec 13, 2009 | 08:10 AM
You are going to do a LOT of fab work. The steering column will be a concern. You'll likely have to move the gear box to the outside of the frame rail. And the pan clearance to the front diff... Yet another issue. It will not be fun.
The best advice I can give you is to get a fab block (fiberglass mock up block that you can bolt headers, etc to to gauge clearances).
Old Dec 13, 2009 | 09:56 AM
_Syclone_'s Avatar
Good idea on the block. I will go to a manual steering unit and a flaming river column. Should make things a lot easier. I have a huge lathe, cnc plasma cutter and full cnc mill to use anytime to make any brackets and parts I may need. I will even make my own sheet metal oil pan. No problem there either. Just wondering about the clearance with a big block versus LS1. I just did a LS1 in my syclone around the front diff. Not to bad actually, but the big block may be a different story.
Old Dec 27, 2009 | 12:26 AM
coivabs09's Avatar
Banned
coivabs09 is on a distinguished road
if you get a v8 you will need a tranny with it, along with a new front end susp. you could just get another v6 and mod it? plus you could save a little money.
Old Dec 27, 2009 | 07:51 AM
The tranny will likely only require a performance rebuild if the donor truck was equiped with a 4.3L. And the stock 4wd front suspension can be beefed up with stronger torsion bars to support even a BBC.
Old Dec 27, 2009 | 08:53 AM
old skool luvr's Avatar
ummm, guys..........the BB has a different bell housing compared to the SB/4.3's. but i'm sure that _Syclone_ already knows that.
here is a thread started a little over week ago that has all the part #'s for the t-bars including the ZR2's (which are probably the heaviest duty available).
if you're serious about this, be sure to start a "Build" thread on it, and post up your progress (& frustrations!). helped a friend drop a 454 into his '88 2WD Dime years ago, and from what i remember, it wasn't all fun 'n games.
IMO, the front suspension would be the 1st main concern (followed by the t-case surviving). if you're building the engine from scratch, i'm sure you're gonna put it on a diet, & use as much aluminum components as possible.
Old Dec 27, 2009 | 09:01 AM
BBC & SBC (including the 4.3L v6) bell housing bolt patterns are the same. Not sure where you read otherwise.
SIK5
Sep 22, 2014 02:33 PM
wrxsubaru
Sep 4, 2014 06:18 PM
checkmarks
Jul 9, 2014 02:37 PM
Revelc
Apr 24, 2013 08:15 AM
Cidium
Suspension Tech
Sep 27, 2011 11:14 PM
