496 BBC Build/Install Thread
Old Sep 16, 2014 | 11:19 AM
SIK5's Avatar
SIK5 is on a distinguished road
Default 496 BBC Build/Install Thread
Hey everyone! I have a 1977 K5 with a few healthy mods on it already. It has a Voodoo Lunati Cam, ported camel hump heads, Victor Jr Intake, Holly 850 Carb, 4" Rough Country Lift (looks like 6"). It runs very well as is.
Alas, I have found myself needing more power and wanting to dip into some sand drag racing. I am building a 496 BBC that sould have around 10.5:1 compression and a 200 shot of spray. I will be using this thread as a way to share my progress.
However, I have the stock TH350 with Dana 44 and coporate 12 bolt still. I honestly believe the previous owner slapped in 2.76 gears to help with fuel mileage. I say this because a year ago I did run it at the sand drags and did not even come close to hitting 3rd gear at the 300' mark.
So heres where I need some advice:
  • TH350 - I need to beef it up to handle the new power. What all needs to be redone? Clutches? I have a shift kit installed already.
  • Dana 44 - I am getting some new 30 spline axles and b eefed up U joints. What gears do I need? 4.10's with LSD?
  • Corporate 12 bolt - 30 spline axles beefed up ujoints and 4.10's with LSD?
  • NP203 TC - I think I will be modding this to be part time 2 wheel drive. I will need new hubs right? What else do I need?
  • Torque Converter - how big?
  • Traction Bar
  • Wheels/Tires - I currently have 15x8" aluminum rims with 33x12.5" BFG All Terrains. Should I go wider with TSL Thornbirds?
  • Suspension - I want to go coil over but that is super pricey. Should I go with a 2" lift instead of the 4"? I need to lower it to make it more stable at high speeds right?
  • Steering - new hydro steering box?
  • Roll Cage
  • 5 Point Harness
  • What else do I need to mod?
I will be posting some pics soon of my current set up just to show ya'll where I am starting from. I look forward to hearing any and all input positive and negative! I got thick skin
Old Sep 18, 2014 | 11:08 AM
SIK5's Avatar
Does nobody else have a similar setup on this forum!? Bueler...buelerrrrr
Anyway,
UPDATE:
Purchasing a TH350 rebuild kit
Did some research and it looks like I already have 30 splines which should be ok. All I need now are 4.10 gears and a install kit with new bearings etc...
Found a true trac with 4.10 gears on craigslist. Will also get an install kit.
Getting a part time kit and rebuilt kit
  • Torque Converter - how big? Still working on that
  • Traction Bar - Offroad Design makes a nice one
  • Wheels/Tires - I currently have 15x8" aluminum rims with 33x12.5" BFG All Terrains. Should I go wider with TSL Thornbirds? Still not sure
  • Suspension - I want to go coil over but that is super pricey. Should I go with a 2" lift instead of the 4"? I need to lower it to make it more stable at high speeds right? Still not sure
  • Steering - new hydro steering box? Still not sure
  • Roll Cage - Adding another roll bar and will have them welded together. Might have a prefab one added in the cab.
  • 5 Point Harness -Eventually
Old Sep 22, 2014 | 02:33 PM
SIK5's Avatar
Pics as she sits now:
496 BBC Build/Install Thread-blazer-1.1.jpg
496 BBC Build/Install Thread-blazer-1.2.jpg
496 BBC Build/Install Thread-blazer-1.3.jpg
496 BBC Build/Install Thread-blazer-1.4.jpg
ravenhurst
28
Dec 1, 2014 08:43 PM
checkmarks
Jul 9, 2014 02:37 PM
Revelc
Apr 24, 2013 08:15 AM
pj5454302
Sep 10, 2012 06:55 AM
_Syclone_
Engine & Internal
Dec 27, 2009 09:01 AM
