pulling motor ?
Old Aug 18, 2006 | 12:32 AM
Hanr3's Avatar
Default RE: pulling motor ?
I would like to add to what swart posted. When you remove the tranny cross brace you lower the back end of the tranny. Then you need about 3' of extensions and a wobble socket to get those top two tranny bolts out. On my '87 it is a 15mm socket, on my '00 it is a 18mm socket, and on the '93 it is a 15mm. All three are 700R4, 4L60E 60dgree and 90 degree trannies. In other words check one of the bottom bolts before you buy the wobble socket, unless your going to buy the whole set.
Old Aug 18, 2006 | 03:04 PM
desrt_rat's Avatar
desrt_rat is an unknown quantity at this point
thanks for the help, gonna tear into it this weekend and hopefully have it running soon. i think i will replace the pan gasket and valve cover gaskets while its out too.
Old Aug 21, 2006 | 02:13 PM
desrt_rat's Avatar
well, mine takes a 18 and no one in town has one, i did manage to get everything loose other than the bell housing, has anyone ever replaced the seal with the motor in, i think i have enouph room to drop the pan down far enouph to do it.
Old Aug 22, 2006 | 10:24 PM
desrt_rat's Avatar
well, here we go, i picked up the seal for a 83 and it turns out that mine is a one piece, if i got the # off the motor can someone on here tell me what year the motor is and what it came out of? it turns out that the motor is dumping oil out of the rubber seal on the back of the pan so now its out with the motor time.[:@]
Old Aug 29, 2006 | 01:29 AM
Hanr3's Avatar
1 piece rear main seal.
2 piece rear main seal.
Notice the difference between the two crank shaft ends? A one piece seal will not fit over a 2 piece crank.
Old Aug 29, 2006 | 06:48 PM
desrt_rat's Avatar
mine is a 1 piece, the # on the block is Canada 14072061 and under that is has 2.8 LG if that helps, i really would like to find out what year it is.
also it has CF021977 stamped on the front.
Old Sep 6, 2006 | 02:19 AM
Hanr3's Avatar
This is by far the best source I have found to identify the GM 4.3L V6 blocks.
Clicky Clicky
Its how I found out that I have a '85 block that I just dropped into my '93.
1997 tricky1
Oct 30, 2011 12:01 AM
1997 tricky1
Sep 29, 2011 10:53 PM
badboy
Aug 3, 2010 12:05 AM
Slayton92
Jul 22, 2009 04:55 PM
ggwash21
Engine & Internal
Jun 17, 2006 02:08 AM
