Ramdom Misfire untill warmed up!
Old Sep 9, 2010 | 06:26 PM
pj5454302's Avatar
Default Ramdom Misfire untill warmed up!
Well heres the problem, When my truck has sat over night it will misfire under light load untill driven about 15 miles. Now I have replaced the cap, roter, plugs and wires and nothing has changed. Thiese guys are having the same problems http://www.s10forum.com/forum/f107/r...-4-3-a-200188/
Now the genral consensus is to replace the fuel injector spider and all the injectors, and/or distributor gear. But befor I do anything what do you guys(and girls) think?
Old Sep 9, 2010 | 08:58 PM
The first thing I would do is check the drain/vent in the base of the distributor. If the drain/vent is not functioning properly, it can allow moisture to build up inside the distributor and disrupt spark transfer between the rotor and the cap.
Old Nov 12, 2010 | 07:08 PM
reapher's Avatar
reapher is on a distinguished road
My 2001 Blazer did this, mechanic said it was probably a stuck lifter. I changed the lifters out in the summer, will have to wait for subzero temperatures to really see if it stopped the problem
Old Nov 12, 2010 | 07:12 PM
robertr728's Avatar
robertr728 is on a distinguished road
Sounds like the dist gear to me. Its easy to check i would give it a look as well as what swartlkk said.
Old Nov 12, 2010 | 09:46 PM
69chevelle's Avatar
69chevelle is on a distinguished road
hmm sounds like the exact same problem I am having after I hydrolocked my motor(might be coincident, but kyle might have my reason)... I'll do some investigating to, keep us informed of what you find.
Old Dec 20, 2010 | 03:41 AM
Caldoeing's Avatar
Caldoeing is on a distinguished road
I have a 2000 Chevy Blazer Zr2. I keep getting random misfire codes. The truck with hiss and pop when you first crank it up in the morning but once it warms up it drives down the road fine. I hear a hissing noise coming from the front driver side and I have no idea if its related to the misfire code.I just replaced all the wires and plugs. I have replaced the fuel pump heater core and countless other items and I am stumped on this problem.
Old Jan 19, 2011 | 10:26 AM
69chevelle's Avatar
If you haven't fixed the problem yet it sound like you have a vacuum leak.probably your vacuum canister which is located in your fender beside your abs box.do a search for a better description.
Old Jan 20, 2011 | 10:02 AM
pj5454302's Avatar
Sorry I never posted back on this thread, Replaced just about everything in my ignition syetem: Ignition controll moduel, Distrubutor pickup, Coil, Plugs wires, Cap roter(both with ac delco replacments). And what ended up being the problem was the distributor drive gear, Replaced it about 3 months ago now and havent had an issue to date.
bam_9_9_9
49
Dec 30, 2012 08:42 PM
rrk03300
Nov 15, 2012 10:29 PM
bulldogauto
Nov 22, 2010 10:37 PM
Rottidog
Apr 15, 2010 09:21 AM
jackburton
Mar 8, 2009 09:34 AM
