Shift Kit
Old Oct 6, 2006 | 12:11 PM
TruckeeT2's Avatar
TruckeeT2 is an unknown quantity at this point
Default Shift Kit
Is it recomended to put a shift kit into my 1993-1994 S-10 Blazer 4.3 W 4x4 Auto. Has anyone else added a shift kit onto there tranny?
Old Oct 6, 2006 | 12:16 PM
EkStreem G's Avatar
EkStreem G is an unknown quantity at this point
Default RE: Shift Kit
Shift kits are so stiff, but they do decrease wear on your trans. The clutches don't wear out as fast because they are barely used when shifting. There are other advantages, I don't know what they are, though.
Old Oct 6, 2006 | 01:36 PM
Benefits include decreased clutch wear due to shortened shift duration. The clutches are still doing the same thing, but the time it takes for full application of force on the clutch packs is reduced so there is less slipage during a shift. Also, due to the fact that there is less slippage, there is less heat generated, adding some life to your fluid.
I helped Scott (4lowlife) put a kit in his '01 (IIRC) Blazer and he has been pleased with the outcome. I plan on putting one in my Bravada sometime as well.
Old Oct 6, 2006 | 01:44 PM
offroaddude77's Avatar
offroaddude77 is an unknown quantity at this point
i thought on the 4l60e you can only change the servos and line pressure
*NEVER MIND answered my own question on montertrans.com*
Old Oct 6, 2006 | 05:47 PM
EkStreem G's Avatar
Now, are the shifts unbearably hard? My sister's Probe had a bad trans. and the 1st to 2nd gear shift was HARD, and it used to suck. If was in that car for too long I would get headache.
Old Oct 10, 2006 | 01:44 AM
TruckeeT2's Avatar
Thanks for all your help
bigdaddykane93
Feb 24, 2013 02:30 PM
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
DrEaMsTeVe
Feb 15, 2011 02:50 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
