STROKER V6
Old Jan 18, 2007 | 01:24 PM
OWENMUSTANG's Avatar
OWENMUSTANG is an unknown quantity at this point
Default STROKER V6
my 97 4.3 motor has had a good life..now, need an upgrade..
i found a stroker kit for my 4.3 will take it out to 272.
looks like the crank is an offset ground 4.3 crank (new stroke is 3.55)
anybody used a stroker kit in their 4.3?
how does it run?
oh, if your going to say "just use a 350" o.k, where do i get a kit to "bolt" it in using the factory fi set up?
Old Jan 23, 2007 | 03:45 PM
20Blazer00's Avatar
Default RE: STROKER V6
To put in a 350 check out Jags That Run, they have a complete manual for around $20+ if you're interested...
I would not put a "stroker" kit in a 4.3 because the crank is not strong enough as an "even fire" design. As I have seen some research on the subject and Hot Rod magazine did an engine build up on a 4.3 the crank is the weakest point in doing a "stroker" 4.3 since the rod journals are offset to deal with the 90* axis of the cylinder banks...to do a V-6 "stroker" you need a 60* version 2.8, 3.1 or 3.4 these cranks have solid rod journals for their cylinder layout...
88K5blaze
Jan 28, 2010 03:01 PM
1oldK5
May 8, 2009 09:26 PM
1oldK5
May 7, 2009 01:43 AM
erauto
Nitrous, Super Chargers, & Turbos
May 20, 2007 03:32 PM
SniperX13
Engine & Internal
Oct 22, 2006 09:23 PM
