thermostat
Old Jul 28, 2006 | 10:45 AM
kelraes's Avatar
kelraes is an unknown quantity at this point
Default thermostat
will a low temp actually do anything? and which one would be better a 180 or 160 degree?
Old Jul 28, 2006 | 01:12 PM
Default RE: thermostat
Need to know more about your truck. Year for one...
Anyway, a 160*F t-stat is much too low for the newer (96+) Blazers as the PCM doesn't induce closed loop status until after the engine has gone over 168*F. So your mileage would suffer.
A 180*F stat could be used, but I doubt you will see any benefit other than lower temps. Winter time running with a 180*F may result in slower heat response from the HVAC system.
Old Jul 28, 2006 | 02:20 PM
kelraes's Avatar
its an 01 LS 2DR 4x4. yeah i thought the 160 would be two low and the 180 isnt much of a diff. well thanks for the reply
GasCan
Dec 3, 2005 12:52 AM
Weshard
Oct 28, 2005 01:26 PM
CKSMartin
Feb 24, 2005 02:39 PM
2001Blazer4x4
Engine & Internal
Feb 18, 2005 04:07 AM
2001Blazer4x4
Oct 31, 2004 01:13 PM
