Thinking about taking out the A/C
Well, considering the A/C clutch is disabled at WOT, you really won't notice any performance differences.
Mythbusters did a test on an suv. The results were mixed. First they connected a computer to the disgnostic connection of an suv. The computer measured the air consumed by the engine and computed the fuel mileage while the Suv traveled around a test track.
Test 1 - same vehicle
With a/c on- 11.7 mpg.
Without a/c and windows open-11.3 mpg.
Test 2
They emptied the tanks of 2 identical suvs, then filled them with exactly 5 galllons of gas, and then drove around a test track at 45 mph for 7 hours until the first one ran out of gas. The suv using the a/c ran out of gas first. The suv with the windows open ran for another 15 miles before quitting.
Kind of conflicting infromation, but I would believe the 5 gallon test more and for 15 miles difference, I'd take the A/C ANY DAY!!! Not to mention that having A/C in the winter time will keep down on the amount of fog in your vehicle as the A/C system actually removes moisture from the air.
Test 2
ORIGINAL: swartlkk
WOT == Wide Open Throttle
That is why I would never remove an A/C system unless it was completely inoperative and would cost more than the vehicle was worth to fix. It doesn't hinder performance much during normal use, and it doesn't at all when you are really screwing around.
smurphy132
Jan 6, 2010 07:14 PM
higgy
Nov 29, 2009 03:09 PM
eastsiderides
Mar 28, 2009 03:20 AM
